86 22r No start
Old Jun 12, 2024 | 07:20 PM
XtraCab2wdLongbed's Avatar
86 22r No start
Hello all,
I've exhausted all of my options so I must turn to you. I have an 86 pickup with the carburated 22r engine that will not start. The engine has 180 psi across all four pistons, has spark, and has a brand-new carb on it. I've ran the ignition off of the truck's wiring and off a separate battery, with no change. I've tried two factory carbs and two Webers. It is almost as if the truck has given up. The engine will fire, but only for 1 second, and roughly. The longest I've managed to get it to run for was 5 seconds, after which it promptly sputtered and died. This issue started when I was driving down the road, the engine sputtered then died, and hasn't run since. Any help would be greatly appreciated. I have another engine but I do not want to resort to doing the swap.
Old Jun 13, 2024 | 10:16 AM
osv's Avatar
osv
is the fuel pump delivering enough fuel to the carb?
Old Jun 13, 2024 | 01:46 PM
prcnctoyo's Avatar
FSM troubleshooting...
BurnNFabSkrt
All Other Toyota Swaps
Jan 28, 2022 10:18 AM
Upsidedown86
Nov 19, 2020 10:07 AM
Matthew Cox
Jun 24, 2019 03:03 AM
Moundsp
Oct 21, 2018 09:18 PM
jburress10@yahoo.com
Nov 11, 2013 11:56 AM
