Hello, I have an 88 4runner with the vent window doors. The doors did not come with any sort of weatherstripping around the main window. So the glass rattles around and doesn't seal. Does anyone happen to know which seals that I need and where I can find them? Thank you.
They’re called window runs, and readily available from either Toyota or aftermarket. With some finesse and a bit of silicone spray you can install without any disassembly.
That’s them. And left and right are the same. There’s also weatherstripping that runs on top of the door(inner and outer) and seals the door glass. They’re usually called belt moldings, but they function as a weatherstrip. They also help cut down on window rattle. Are those missing too?
