new water pump
Old Jun 13, 2024 | 09:26 PM
jdfnnl's Avatar
new water pump
Would most people opt to replace the water pump along with a new radiator and coolant flush?
Is there a major difference between these choices? (https://www.oreillyauto.com/shop/b/e...-toyota-pickup)
Or maybe this one is good enough? (
Amazon Amazon
Old Jun 13, 2024 | 09:45 PM
millball's Avatar
There is no reason to change a water pump that is not weeping from its bleed holes and whose bearings still feel tight and smooth.
Old Jun 14, 2024 | 02:02 AM
snippits's Avatar
If it ain't broke, don't fix it.
If I needed another one, I would buy Aisin again. Mine had a grind mark, and that's because the manufacturer ground off Toyota marking.
Amazon Amazon
Old Jun 14, 2024 | 05:37 AM
jdfnnl's Avatar
what does weeping from the bleed holes indicate?
Old Jun 14, 2024 | 06:14 AM
snippits's Avatar
Leaking from the pump weep hole indicates bearing is bad. I plugged the weep hole on a 1970 Pontiac Catalina 400 engine with Juicy Fruit chewing gum, and it ran like that for years and years.
Old Jun 14, 2024 | 08:41 AM
Jimkola's Avatar
YT Community Team
5 Year Member
It would indicate the inner seal has failed, allowing water into the bearing. Once the hot water circulating through the cooling system flushes the grease from the bearing it'll start to wear down.
The weep hole gives you advanced notice that the waterpump has developed issues.
Odin
Aug 27, 2016 07:56 PM
peow130
Jan 19, 2011 01:23 PM
808Yodi
Dec 28, 2009 05:16 AM
yoterBoater
Apr 25, 2008 04:51 PM
DrummerDaveB
Aug 3, 2004 11:51 AM
