Timing chain and ignition timing
Old Jun 17, 2024 | 02:07 PM
Grimmfrost's Avatar
Hello, new member here. I had a bad camshaft seal leak so I replaced the seal. I lined up the cam gears with the crank shaft pointing at 12 o'clock and 0 respectively but, now it has no power or acceleration. It starts fine and idles really low but doesn't stall ( probably around 6krpm).
**This is an 89 pickup 4x4 with a 3vze **
1. Do I need to pull this appart again and redo timing belt?
2. Or do i need to just adjust ignition timing?
3. If i do have to pull it apart is there a way to just take the platic timing cover off without pulling the fan and pulleys?
Any help will be appreciated
Old Jun 22, 2024 | 10:50 AM
Grimmfrost's Avatar
Update
Got it fixed!
Bought a 30 dollar timing light at harbor freight and set the timing to (10) runs great.
To set timing
1. Warm up truck
​​2. put a wire or paperclip on (te1 and e1)
3. Connect timing light to battery and clip cylinder 1 plug wire, facing sparkplug 1 ( there's an arrow on the clip)
4. loosen distributor cap bolt with 12mm
5. Twist cap till crank pulley lines up with (10ish). Then tighten the bolt back down. 👍🏼
Obmi
Jan 4, 2016 06:22 PM
asmooth13
Sep 8, 2014 02:10 AM
bc56845
Jan 20, 2012 07:41 PM
sleepygreen
Nov 26, 2010 01:06 PM
DrCreosote
Sep 10, 2010 07:55 AM
