steering issues
Old Nov 28, 2011 | 04:02 PM
steering issues
today while I was turning into the lot at work my steering started binding and popping , then it stopped , did it after work again then it stopped , I checked everything I could think of , but I cant get it to do it now , any ideas ?
Old Nov 29, 2011 | 04:11 PM
sechott's Avatar
If it happens only when wheels are locked in either direction, It is most likely the rubber/plastic stops have worn and bare metal is grinding. No harm just sounds terrible.
Old Nov 29, 2011 | 04:27 PM
xxxtreme22r's Avatar
X2, but does your truck have ADD or manual hubs? If ADD It could also be one or both CV axles as well.
Old Nov 29, 2011 | 05:25 PM
john4wd's Avatar
From my build thread about stopping the creaking from full steering turning.
Yesterday I turned all 4 of the steering stops 180 degrees to use the bottom part not wore out and before I put the caps back on I sanded down the bolt under cap smooth and sanded the contact area smooth on the knuckles and greased the caps :}
Easy Peasy!!!!
The pic is from before I turned them 180 degrees, instead of the brown part being up where it's warn through put that area down and the clean black plastic area up and grease the surface, it's a very easy cheap fix.
If the steering stop cabs are cracked and won't stay on they'll have to be replaced, when removing them just go back and forth top and bottom then top then bottom prying to remove them carefully so not to brake them in two then you will have to get new ones...There only 5 bucks a piece at dealer...Here is a link to get aftermarket ones on ebay...
http://www.ebay.com/itm/86-95-TOYOTA...sories&vxp=mtr
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
