94 4runner won't shift to 5th
Old Dec 5, 2011 | 01:40 AM
ilovemitchellc's Avatar
1994 3.0 automatic 158,000 miles. Driving on the freeway 70-75 mph and it won't shift at 4,000rpm. I just got an oil change, was told to try changing tranny fluid? Any ideas? OD going out?
Old Dec 5, 2011 | 04:32 AM
sechott's Avatar
Auto should be a 4 speed?
You should check the AT fluid level, the shifter linkage could be out of adjustment or it might be the torque converter not engaging the lock-up, which sometimes feels like a 5th gear change. If none of these it could be the computer not getting a signal to shift into overdrive or transmission troubles.
Old Dec 5, 2011 | 09:38 AM
Paul H.'s Avatar
Mine runs just over 3000rpm at 70mph and it is only a 4speed auto like sechott said.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
crashburnoveride
Jul 10, 2015 06:39 AM
Jnkml
Jul 6, 2015 01:20 PM
