Windows hard to roll up when cold
Old Dec 8, 2011 | 12:24 PM
Mr.Utah's Avatar
My 87' x-tra cab has bad rubber seal around the doors, where do I find new door seals?
Also, it's cold now, windows extremely hard to roll up and down, What is the fix for this? I have no idea how to remove interior door panels!
Thanks, Utah
Old Dec 8, 2011 | 12:54 PM
john4wd's Avatar
For the seals you have to ask yourself you want the easy way or are you willing to do some running around to get cheap ones
Go order new ones from dealer, or check JCWhitney.com if you can order from them if available for you make model and year.
Or go to a salvage yard and get some good ones from another truck, but being that old and in your same area I bet there ripped also, the seals rip easily where there mounted to the door with the T clips, call around first to see if they have any 84-89 truck/4runners there, all the doors are the same and use same seal.
I bet the window assemblies are really gummed up from being that old and dirt dust and crap, a good cleaning and re-greaseing would liven them up, and the doors panels are easy to take apart, there is one screw holding the door handle trim, when you take out the screw on the dooh handle it will come off then there ia a rod attached to the door handle that is red I think it has a swival clip that hooks on the curved end rod and you just take your finger and it pops off the rod with little effert and there are 2 screws holding the arm rest on, and there is a horse shoe clip that holds crank on, do you have a Harbor Freight? if so go get there 4 piece door trim removal tools (gold color) and they have a crank clip removal tool, be carefull the clip will fly out when removed, and another tool to pop out the plastic clips holding panel to door , there like 4 to 5 inches spread apart all along three sides, the sides and the bottom, it's easy, take your time and do as I instructed you'll be fine :}
Old Dec 8, 2011 | 02:05 PM
Mr.Utah's Avatar
Thanks..... I will try this!
Old Dec 8, 2011 | 02:09 PM
snobdds's Avatar
Get a new window regulator. The gears get striped out and make it hard to roll up. Rockauto.com has them at good price.
Old Dec 8, 2011 | 02:20 PM
john4wd's Avatar
Ya it could be the mechanical regulator too, great point, they do wear out, if he does the salvage yard for the seals if they have any drivers doors he can see how they roll up and down and snag a drivers door one that works smoothly.
He never said if he had mechanical windows or electric ones, so I assume mechanical ones...
Old Dec 8, 2011 | 04:19 PM
Mr.Utah's Avatar
ok...these are not power windows, good old-fashion hand roll ups. So what do I lube up the window lifter with.....Grease? Oil? Thanks
Old Dec 8, 2011 | 04:21 PM
Mr.Utah's Avatar
Oh, and thanks for your expertise!!
Old Dec 8, 2011 | 05:48 PM
92dlxman's Avatar
im watching this very closely. i dont care about my windows bein a lil sticky, but when other people get in, i watch them put all kinds of effort into that poor little plastic handle without even thinking to help it out by pushing/pulling on the glass.
it is for the sake of my passenger door that i must learn this. thanks for having the same problem man, weird that its only cold right? when hot they are smooth. dont get it
Old Dec 8, 2011 | 08:12 PM
john4wd's Avatar
I went to this site (http://www.toyotapartseast.com/) and looked up the door regulators for a 87 xtra cab and there under a hundred and that isn't to bad and would be close to dealer price, I would just get a new one!!!!
Old Dec 8, 2011 | 09:38 PM
Keith B.'s Avatar
New regulators may help. In the meantime, you can try dribbling silicone spray down the channel that the glass rides in. This has almost always given some relief when I have done it. Pick a silicone spray that doesn't have a creepy, Liquid Wrench or 3-in-1 oil smell added to it.
Old Dec 9, 2011 | 02:40 AM
CRamsey's Avatar
Temporary Fix
I had this same problem and can offer my temporary fix. The rubber in the window track had become worn and split inside the door, allowing the window to cock a little sideways and bind up when going up or down. I pulled the door panel away from the door and got to the split track closest to the rear of the door. I glued (with weatherstrip adhesive) the split rubber part back together and then glued and clamped it into the metal track that holds it in place. After putting it back together, it works almost as good as new and has held for a year so far. It's definitely easier and less expensive than a full replacement.
Old Dec 9, 2011 | 10:01 PM
Mr.Utah's Avatar
My plan:
Money not an issue. I will order new seals and hopefully refurbish the regulator. I will post pics if my son helps me out. Thanks for all the responses.
Old Dec 10, 2011 | 04:05 AM
sinful's Avatar
hi
whats the best way to lubricate the window seals? I tried wd-40 and it only works for a few days and they become hard again.
Old Dec 10, 2011 | 10:35 PM
john4wd's Avatar
I would try some high quality silicon sprays or silicon grease...
Found on Amazon about revitalize rubber...
Silicon grease, such as Permatex 22058 Dielectric Tune-up Grease - 3 oz. or Fantasea Silicon Grease Lubricant, "for all types of O-Rings" not only revitalizes rubber of all kinds, but also has a wealth of other uses. And it is cheap, considering that one tube lasted me for 20 years. I just bought a replacement tube.
When treating rubber, rub the silicon grease into the rubber with a cloth, let it set for a while, and then and wipe off excess. It probably helps if the silicon grease and the rubber are warm. You may need several cloths, because the process also cleans oxidized rubber (carbon) from the surface. Several applications may be necessary for badly deteriorated rubber. Within reason, you cannot use too much silicon grease, and you do not have to wipe off moderate excess (except for faucets, water filters etc)---silicon grease does not attract dirt, and is not corrosive of plastics or electronic components.
If you are tempted to try petroleum-based oil or grease for this purpose: STOP---petroleum-based oil and grease DAMAGE rubber. I once ruined an expensive computer plotting machine by using "white grease" on a squeeky component---the fumes "rotted the irreplaceable drive belts. Petroleum oil and grease can also be corrosive of plastics and other petroleum-based items. NEVER USE PETROLEUM BASED OIL OR GREASE ON RUBBER PRODUCTS.
Old Dec 11, 2011 | 09:34 PM
sidebarr7's Avatar
To grease them? Use fluid film thats the name of it ,google it to find where to buy,Also makes a good under coating for truck.
jasonty
41
Dec 23, 2018 01:00 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
RustBucket
Jul 24, 2015 04:46 AM
94yotaky
Jul 23, 2015 07:50 AM
icentropy
Jul 14, 2015 10:23 AM
