EGR Temp sensor code after header install (code 71)
Old Dec 4, 2011 | 08:33 AM
Squeebs's Avatar
atleast i think it was code 71. if my mathematican is right.
Installed a downey long tube header on my 94 22re, now its throwing the egr temp code.
Could it be as simple as a bad gasket on the EGR tube?
And where the heck is the EGR temp sensor?
Old Dec 4, 2011 | 09:20 AM
Squeebs's Avatar
EGR temp sensor is on the firewall side of the intake manifold, right? little dinky thing?
Maybe pull it out, hit it with some electronics cleaner and a tooth brushe and give the threads some new PTFE tape?
Old Dec 6, 2011 | 07:57 PM
Squeebs's Avatar
pulled the sensor, it was covered pretty badly in carbon deposits.
soaked it in seafoam for a bit, hit it with a wire brush, now its clean and purty.
reset the light, plugged everything back up.... now just gotta wait and see.
Old Dec 8, 2011 | 09:37 PM
Squeebs's Avatar
and.... lights back on, same code.
either i shell out 125 bones for a new sensor, or i find a jury rig. ill get back to you all.
thanks for all the help, by the way. haha.
Old Dec 9, 2011 | 02:31 AM
TinMan's Avatar
Put a ten ohm resister in the wiring harness side. It will trick the ECU.
Old Dec 9, 2011 | 04:20 AM
TNRabbit's Avatar
Not 10 ohm; 10,000 ohm resistor.
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
bryan34w
Jul 6, 2015 05:53 PM
