Where to get gasket?!?
Old Dec 3, 2011 | 11:17 PM
Mdumaw's Avatar
Anyone know where to get the gasket between the exhaust manifold and turbo on an 86 22rte? it has a ct-26 swap, and am not sure to try to find a gasket for the ct20, or ct26. Same size?
I've tried (although figured it wouldn't work :p ) ultra copper rtv
Old Dec 4, 2011 | 12:57 AM
wyoming9's Avatar
Wink
Make your own.
I have some Mr Gasket exhaust gasket paper in a 12" square that should work just fine.
Old Dec 4, 2011 | 11:46 AM
Turd Furgeson's Avatar
gasket paper probably isn't gonna cut it on a turbo application.......the gaskets are stainless steel to hold up to the extreme heat and pressure involved. I think you want the ct26 gasket. I think I heard the ct20 gasket is close,but still smaller than the entry port for the turbo. If you have the stuff to do it you should use the old gasket as a template and port the manifold to match the gasket size.You can get a ct20 gasket from lc engineering,and probably the dealership. The ct 26 gasket.......probably the dealership or some sort of place that specializes in supras. I don't remember the name of the website,but I have ran accross a supra website out there that probably has it. This maybe http://www.horsepowerfreaks.com/part...kets/CT26/5082
Old Dec 7, 2011 | 11:59 PM
Mdumaw's Avatar
hey its been a little while since ive been on, seeing as i have to take care of my father with his L1 compression fracture, he swerved to miss a deer and hit a driveway jumped like 25 feet and landed pretty hard long story short no internet there. but thanks i'll probably end up hitting up a dealer for that. i've looked all over. but thanks i was just making sure i didn't miss somewhere you guys knew of!
_Nicco_
Sep 21, 2015 03:06 PM
Obmi
Sep 16, 2015 02:13 PM
bootscootboogie
Sep 5, 2015 05:57 AM
Scotto6591
Sep 3, 2015 07:38 PM
scottyg486
Jul 19, 2015 05:34 PM
