86 22re wont start after alternator and water pump replacement.
Old 12-11-2011, 10:47 AM
andlours's Avatar
I went ahead and replaced my water pump and alternator because I had signs that both of them were going bad. I reassembled everything, after charging my battery, and the car wouldn't even turn over. No charge lights turned on the dash, and none of the cab lights worked either. The only thing that worked were the headlights. Is this just a fuse or my battery or what. Any help would be appreciated. Thanks guys!
Old 12-11-2011, 11:42 AM
peckinpah's Avatar
Could be your 80 amp alternator relay. It's under the hood in the fuse box there. However, it's bolted in, so keep in mind that you can't just pull it out. You have to take out the bottom of the fuse box, and unbolt it from there, IIRC.
Once out you can test it with a multimeter. If that is the problem, they are cheap and available at any auto parts store. If it's not that, it could be a defective alternator. I would pull it out and have it tested at that point.
Old 12-11-2011, 02:56 PM
andlours's Avatar
So it is my 80 amp fusible link, but I have no idea how to undo the clamp holding it in to the box, to push the whole unit down. How do I undo that clip holding it in?
Old 12-11-2011, 07:25 PM
andlours's Avatar
I got it all resolved. She run great! thanks for all the help
Ichneumon
09-27-2015 04:21 PM
noahstancik
07-10-2015 11:18 AM
puddlepirate
06-30-2015 05:08 PM
paxanders
06-21-2015 06:29 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: 86 22re wont start after alternator and water pump replacement.
