22RE leakage question
Old Dec 5, 2011 | 08:34 AM
Rockin's Avatar
Hello all. Tried the search but must not be using the correct terms. Got my 22RE rebuilt about 15,000 ago and it has now started leaking engine oil at the junction of the head, block, and timing chain. What are the most likely causes and is there an easy fix without ripping it all back apart.
Thanks...
Old Dec 5, 2011 | 08:37 AM
irab88's Avatar
got any pics? that would help a bunch
does it drip oil when parked? is it all over the engine bay, or just in that one location?
check the following:
-front half-moon plug
-head gasket at that junction
-distributor
-timing cover gasket
Old Dec 5, 2011 | 12:20 PM
Rockin's Avatar
I will take a peek at those and try to post up some pics if I can't figure it out after checking those. Thanks.
Old Dec 5, 2011 | 08:05 PM
92dlxman's Avatar
prolly timing cover gasket. thats a tough junction there with 3 parts coming together at one 90deg. corner. many people replace the cover without ever loosening the head. my attempt at that resulted in a smashed head gasket(it extends to seal between t-cover and head) sound likely for your case?
a leaking front crank seal can get oil slung in places that you didn't know there were places. engine running and skidplate removed is the only way to verify if its good or not. a slow drrrrrrriiiiiiiiiiippp coming from inside, behind, under, (however you choose to describe) the crank pully
Old Dec 5, 2011 | 11:20 PM
cman1's Avatar
powerwash,drive ,inspect.....
p.s if the engine was in fact re-built,i would pull the valve cover,check the hidden bolt,in the very front in the small puddle of oil and make sure its tight to specs,also check the half moon gasket in the front,even reseal it.
Old Dec 6, 2011 | 03:15 AM
irab88's Avatar
ooh, good point ^^
i forgot about the hidden bolt inside
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
