heating issue
Old Dec 1, 2011 | 11:30 AM
carpedevus's Avatar
heating issue
alright so i just bought my 1991 short bed dlx with 180 for 1200 bucks... the heat didn't work so naturally the thermo was my first guess ... turns out the thing was upside down so i flipped it right side up, flushed the system and poof i got great heat... only problem now is when it heats up and runs for a few miles it slowly gets to the point where it wont idle.
any ideas what the hell is going on here? i checked all the breathers .. nothing is disconnected
thanks for the help
jono
Old Dec 1, 2011 | 11:52 AM
93toyrunner2's Avatar
Engine size?
Have you pulled codes yet? Download the FSM from the link in my signature, and open the part about diagnostics. Check for codes, follow the diagnostics charts with a good ohm meter and see what you find.
Old Dec 1, 2011 | 12:32 PM
carpedevus's Avatar
the check engine light isnt on or anything like that .. will it still throw codes?
Old Dec 1, 2011 | 01:00 PM
Yes, they can be stored without the light staying on all the time.
Old Dec 2, 2011 | 09:53 AM
carpedevus's Avatar
well thats the strange thing is the light never came on in the first place... also i have a code checker but couldn't find the plug for it, is this thing obdII or no?
Old Dec 2, 2011 | 10:01 AM
No, it is not OBDII.
See the "MFI System diagnosis" section and it will show you how to pull codes.
Old Dec 2, 2011 | 10:07 AM
carpedevus's Avatar
i was looking at those but couldnt find one for my body style should i just go off the one for 4 runners with the same engine? thanks for the help man
Old Dec 2, 2011 | 10:08 AM
snobdds's Avatar
Pulling codes will get you nowhere, there is not a system on the truck to correlate heat and idle issues.
I do agree we need to know what you have engine wise to help you out. Until you provide that info, anything is a shot in the dark, at best.
If I had to wager a guess, and at this point it's only a guess...it's your idle air control valve. It works off the temperature of the coolant to allow more or less air to the throttle body. If it’s staying closed, your effectively choking the engine of air…
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
jjrbus
Jul 19, 2015 02:06 PM
Poncho0206
Jul 10, 2015 06:21 PM
Coreyr384
Jul 10, 2015 11:13 AM
