Replacement of power steering pump on '93 4 Runner
Old Nov 28, 2011 | 07:30 PM
RiboRunner's Avatar
Smile Replacement of power steering pump on '93 4 Runner
I need to change the power steering pump on my 1993 4Runner, but my Chilton says that because I have rear anti-lock brakes only a dealership can do this job. (Rear wheel ABS, non-integral) Is that true, or is there a way around this? I have had the Chilton make this claim on other projects that I had no problem accomplishing. Any information would be awesome!
Old Nov 29, 2011 | 12:22 AM
wyoming9's Avatar
Wink
I think Chiltons proof readers were slacking or went to the potty when that chapter came up.
It makes no sense what so ever that the brakes are connected to the power steering fluid. Are we putting brake fluid in the Power steering pump.
Are there any brake lines that need to be disconnected to get the pump off that could only be the reason but they fail to mention that!!!!
Old Nov 29, 2011 | 07:08 AM
RiboRunner's Avatar
Thank you wyoming 9!
Thank you for that comment wyoming9! That is exactly what I was thinking when I read the manual, but since I am pretty new to the Yota, I figured I better make certain. Didn't wanna find out about any strange adaptations the hard way!
Old Nov 29, 2011 | 09:32 AM
JohnVH's Avatar
forget that, I have rear antilocks and I changed the whole engine, no worries.
Old Nov 29, 2011 | 10:07 AM
93toyrunner2's Avatar
The power steering does have something to do with the ABS actuator on Rear ABS systems:
I can not explain it, as I am looking into my system as well, but there are break lines going into this actuator that also has power steering pressure lines to it.
Old Nov 29, 2011 | 02:38 PM
RiboRunner's Avatar
Smile
Thank you for all the information guys. Based on the combination of comments, I am guessing that I can do the job, but probably need to include bleeding the lines as part of the project, just to be safe! Thank you for including the link to manuals as well, that should help me with study preparation. I know Chiltons are not always the best manuals to go with, they just tend to be the most accessible.
Old Nov 29, 2011 | 02:42 PM
RiboRunner's Avatar
Or maybe even just clamp the line to the actuator before removing the hose... This probably makes most sense. I am totally open to further comments on the subject, otherwise, I will let you all know how it goes!
Old Dec 8, 2011 | 12:03 PM
RiboRunner's Avatar
All taken care of, and no problems! Thank you for all the input guys!
voiddweller
19
May 2, 2016 09:10 PM
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
paxanders
Jun 21, 2015 06:29 AM
