Pulled off my rear driveshaft and found this...
Old Dec 1, 2011 | 01:27 PM
defrag4's Avatar
Big ol chip in the transmission/transfercase side nut there.
Should I be concerned? I was removing it to diagnose the gear chatter issue I have been experiencing, chatter went away when I removed rear drive shaft btw, looks like need a CV driveshaft/shim up the pinion
Old Dec 1, 2011 | 01:29 PM
Philbert's Avatar
I think that's actually normal - for those bolts/nuts, after you torque it to spec, you tap with a hammer/chisel to really secure it on there so it doesn't back off.
I could be wrong but I've seen that before.
Old Dec 1, 2011 | 01:36 PM
rattlewagon's Avatar
Youre correct. .
Old Dec 1, 2011 | 01:38 PM
BMcEL's Avatar
It's called a stake nut. Normal.
scuba's Avatar
It's called a stake nut. That's normal.
Old Dec 1, 2011 | 01:39 PM
scuba's Avatar
There's a parrot in the room.
Old Dec 1, 2011 | 01:41 PM
defrag4's Avatar
thanks guys
damn newbie over here!
Old Dec 1, 2011 | 01:47 PM
Philbert's Avatar
STAKE NUT!!! STAKE NUT!!! (flaps wings)
sounds like your diff is the likely culprit.....is it leaking? check the oil level?
STAKE NUT!
Old Dec 1, 2011 | 01:50 PM
defrag4's Avatar
Diff is good, checked the oil today and had it all apart in the last 6 months.
I lifted it 2.5 inches with the OME suspenion lift and this problem started, I have a feeling its something with the driveline angle. I have heard I need a CV driveshaft or to shim something up??
Old Dec 1, 2011 | 01:53 PM
Philbert's Avatar
You may need shims between the leaves and the axle, to make the diff/pinion line up with the output from the tranny. I heard recently it's 1 degree of shim for every inch over stock you lift the rear.....
4crawler here sells shims - maybe reach out to him?
good luck!
PS - maybe it was whatever you were doing to the diff when you had it "all apart"? Just sayin
Old Dec 1, 2011 | 01:55 PM
defrag4's Avatar
good luck!
ha tell me about it, seems everytime i take something apart i create a new problem. oh well, thats how you learn i guess!
defrag4's Avatar
oh and I followed your RearDiff gasket change writeup btw! thanks
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
icentropy
Jul 11, 2015 07:21 AM
Avenged
Jul 9, 2015 07:55 AM
Gamble_STi
Jul 7, 2015 07:54 PM
