1991 toyota 22re lower efi manifold question
Old Dec 1, 2011 | 10:48 PM
kevinchester's Avatar
Ok so today we were taking the evi off to change my head gasket buit noticed that their was tinny little puddles of oil in the bottom of the manifold. Can that be from the head gasket or something else bad plz help.
Old Dec 1, 2011 | 10:49 PM
Efi srry
Old Dec 1, 2011 | 11:43 PM
94 toyota 12" lift's Avatar
i had that problem once but it was cuz the truck was rolled. maybe you flex the truck sometimes and oil goes up and stays up it has no easy way back to the engine.
Old Dec 2, 2011 | 06:15 AM
snobdds's Avatar
Blow by caused by the rings not sealing like they use to. Check your cylinders when you get the head off. Idealy you would want to do a leak down test, but you need the head on to do that...
Old Dec 4, 2011 | 06:41 AM
89tonkatoy's Avatar
mine he the same thing and rite where intake tube meet intake it has some oil spots , im thinkin mine is from the front hose on valve cover though or bad pcv valve
zd92655
Mar 6, 2022 12:58 PM
Aleeex_u
Jun 5, 2016 06:52 PM
ConvertedYotaMan
Nov 29, 2015 09:06 AM
bprice0077
Jun 25, 2015 07:36 AM
