89 yoda starter
Old Apr 3, 2009 | 01:34 PM
j0hNnI's Avatar
89 yoda starter
replacing everything on this yoda i bought a couple months ago clutch transmission all that but im having an extremly hard time getting the starter out i got the bolts off i just cant seem to get it out lol if someone could give me some insight besides taking off the motor mount on a 89 yoda 3vz engine that owuld really help
Old Apr 3, 2009 | 01:44 PM
RMA's Avatar
RMA
Have you tried removing the plate that is at the passanger side wheel well, Makes things alot easier.
Old Apr 3, 2009 | 01:49 PM
j0hNnI's Avatar
yea i have a weird clutch line its all looped around everywhere i just got the truck i cant get through the wheel well to it
Old Apr 3, 2009 | 01:57 PM
Junkers88's Avatar
There is a plate??
God I feel like a noob.
Old Apr 3, 2009 | 02:04 PM
toyota4x4907's Avatar
Junkers, it's either a 3.slow thing or he's talking about the hard plastic gap cover thingy
Old Apr 3, 2009 | 02:08 PM
Junkers88's Avatar
Oh thank God. I fought and fought to get the damn battery cable hooked back up since there wasn't any room for my little arms in there. At one point I thought about cuttting in an access hole just to make it easier.
Old Apr 3, 2009 | 02:25 PM
DeathCougar's Avatar
Easiest way i have found to remove the starter is to remove the 2 12mm holding on the clutch slave cylinder (this allows the setup to move) then remove the two 14mm starter bolts with a long extension. Long enough to be in front of the diff. Makes it 200x easier.
Old Apr 3, 2009 | 02:38 PM
Matt16's Avatar
I removed the charcoal canister and took off my jacket and was just able squeeze my arm to reach the top bolt (actually, its a stud and nut) with a box wrench. I did scratch my arm to on the fuel line brackets. For the bottom bolt I used a 10" extension and turned it through the access panel.
You're probably going to need a breaker bar to break the nut and bolt that hold the starter to the bellhousing loose. I slipped a pipe over the socket wrench.
Old Apr 3, 2009 | 03:41 PM
j0hNnI's Avatar
rma ur a baller i got the plate off moved the lines an stuff an took the starter out through there
ladybugRC
458
Aug 21, 2020 10:41 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
ToyotaMD
Sep 7, 2015 04:44 AM
