EGR/Vaccum Question?
Old 03-31-2009, 05:14 PM
Kiroshu's Avatar
You all know where the EGR valve tub goes into the intake i want to know how long or far the hole is inside the intake where the EGR goes. I'm trying to clean it and want to know best way how.
Old 03-31-2009, 08:23 PM
scope103's Avatar
I assume you are asking about the 4 cyl, in which case I won't be of much help ....
On the 6 cylinder, the egr tube is about 10" long, and fits into a hole in the plenum that is about 1/8" bigger all around. Mine was so fouled that I almost couldn't pull the EGR tube out. Then how do you get in there? (You come in from the throttle end, but it's still not big enough to even put your hand in.)
In the end, I removed the plenum (part of a head job) and soaked it in dishwasher detergent. I used a bottle brush to scrub out as much crud as I could. Then I used a 1/2" square stick to scrape the dried hard stuff remaining after the oil was washed off by soaking.
Did it help? Oh, yeah. Before: my A/C and power steering idle-up didn't work, after: they did.
Old 03-31-2009, 11:10 PM
abecedarian's Avatar
depends on the year- the earlier ones had the EGR tube go about 75-80% of the way from the rear of the manifold to the front and later had the EGR tube go about 50%
Old 04-01-2009, 11:34 AM
Kiroshu's Avatar
Mines an 86 22re. So it really does go up that far...So mine being an early 22re would be almost to the throttle plate? Any suggestions on cleaning it out or if needed?
Old 04-01-2009, 01:15 PM
iamsuperbleeder's Avatar
my 91 looked like it came all the way to the front and dumped out right onto the TB
the combination of that and running a rich mixture becaues of a bad O2 sensor lead to this:
the first picture is of the upper manifold with the TB removed, and the second one is of the back-side of the TB...
nasty stuff...
oh and if it helps, here's a shot of INSIDE the upper plentum; you can see the EGR tube on the right side of the picture (technically it's the top-left of the plentum; the picture is on it's side) and it's actually part of the plentum
lectric80
08-11-2015 12:02 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: EGR/Vaccum Question?
