head unit problem 94 PU
Old Apr 1, 2009 | 05:20 PM
zachw90's Avatar
94 pu 3vze 5 spd
i've looked around on tons of threads about this and can't come to a conclusion. i hooked up a sony xplod head unit by splicing wires( i know a harness would be better) and i can't get the back speakers to work if the cd player or aux is on, only the fm radio.. there's only one blue wire on the harness for the sony xplod. does this mean i have factory amps? if so or if not, what do i do??
Old Apr 1, 2009 | 05:26 PM
Tubbyfatty's Avatar
Take it to a stereo place and have them professionally install it. The PO for my runner getto installed my old deck, they fixed it right up.
Old Apr 1, 2009 | 05:53 PM
zachw90's Avatar
i was hoping to avoid taking it to a shop
Old Apr 1, 2009 | 06:06 PM
iamsuperbleeder's Avatar
I'm confused here
so you just installed a head unit, or a head unit AND an amp?
sounds like you have a power antenna output on you head unit, not a remote amp turn on, and that's what's connected to your amp power
the power antenna output will ONLY be hot when the radio is selected
a remote amp power output will ALWAYS be hot when the head unit is turn on, no matter the play-back source
did you buy your head unit brand new? if so, look closer at the wiring diagram to see if there is in fact 2 separate outputs for a power antenna and a remote amp power-up
if all else fails, take that wire you spliced into the blue wire off the head unit (the wire leading to the amp's power-up input), and hook it to a switched 12v with the key, so that the amp will ALWAYS be powered on with the key turned, thus solving the problem
I've never bought a direct wiring harness for ANY stereo install; I've always hard-wired them in myself
Old Apr 1, 2009 | 06:10 PM
John101477's Avatar
I do recommend a shop BUT if you are bound to diy here is the stock wiring colors for the toyota double check what you did.
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Just remember the stock wiring is ALWAYS different colors than after market. i.e constant =yellow, battery = red, aux amp turn on = Blue etc. your stock wiring will not have a aux turn on. that is a seperat wire you have to run.
Old Apr 1, 2009 | 06:11 PM
that's good info to have
the dimmer wire in particular, cause now I know where I can get the dimming use with my aftermarket gauges!
Old Apr 1, 2009 | 06:12 PM
Tubbyfatty's Avatar
It was like 45 for me but i understand.
Old Apr 1, 2009 | 06:13 PM
where are you at; drive it over here, I'll fix it fer ya
Old Apr 1, 2009 | 06:18 PM
zachw90's Avatar
i'm talking about a factory amp.. i'm not sure if i have one preinstalled for the back speakers? and i wouldn't know what wire from the dash would go to that..
those charts are what i used and were mostly correct but as i said i dont know what to connect to power the amp or what to do to bypass it.. i'm replacing all four speakers too so if i could bypass it that'd be better...
Old Apr 1, 2009 | 06:22 PM
zachw90's Avatar
also i got the head unit about a year ago it was spliced into my old honda so i just had the head unit and the wire harness i went by the installdr.com wire colors for typical stereos because they all matched what the sony had
Old Apr 1, 2009 | 06:24 PM
you mentioned a blue wire from the head unit...
a solid blue wire is a UNIVERSAL for the amp output on aftermarket head units
did you connect this to anything at all?
if the back speakers are at least working in radio, this leads me to believe a stereo problem...
for some reason the head unit turns off the rear output in CD player? maybe it only outputs through RCA jacks? not sure why that would be the case, but who knows...
Old Apr 1, 2009 | 06:28 PM
zachw90's Avatar
yeah i had it on the antenna... and when i played am/fm radio the back speakers worked
what's the model of your xplod head unit?
Old Apr 1, 2009 | 06:46 PM
zachw90's Avatar
sony xplod cdx-gt07
Old Apr 1, 2009 | 06:49 PM
gary96360's Avatar
maybe the headunit is faulty
.i was wondering what size of speakers are in the front? need to upgrade
Old Apr 1, 2009 | 06:52 PM
zachw90's Avatar
haven't measured..i heard four but also alot of people have problems putting them in. thats what i plan to do next
Old Apr 1, 2009 | 06:55 PM
sony xplod cdx-gt07
okay, so, you should have the standard 16 pin Sony connector on the back, correct?
In which case, what is the solid blue and the blue/white wire from your HEAD UNIT attached to?
Old Apr 1, 2009 | 06:56 PM
zachw90's Avatar
there isn't a blue/white wire..there's a solid blue and on the toyota dash yellow is labeled as a speaker
Old Apr 1, 2009 | 07:06 PM
zachw90's Avatar
mine only has 12 wires in it..and blue/white is not one of them... do you think i could use the spot it's listed as and insert a wire?
Old Apr 1, 2009 | 07:10 PM
John101477's Avatar
honestly dude if you have the blue wire(on head unit) hooked to anything take it off! second the Yellow of the stock wiring is speaker but the yellow on the deck is constant power. the yellow from the head would connect to the blue/yellow. if you do not have a blue yellow then some body had done already jacked ur truck. ok here is an easy question. did your old head usit say JBL on it? if not then i doubt it is amplified.
if so remove the old speakers and run new wire and buy some new speakers
