head unit problem 94 PU
Old Apr 1, 2009 | 07:11 PM
John101477's Avatar
dude - do you have a multimeter? you could check all this in about 20 min or less with one.
Old Apr 1, 2009 | 07:14 PM
zachw90's Avatar
it didn't say jbl. the stock radio had a blue/yellow/pink wire is that what you're talking about? it was listed as antenna i believe
John101477's Avatar
also read this.
https://www.yotatech.com/forums/f96/...problem-44990/
Old Apr 1, 2009 | 07:16 PM
John101477's Avatar
then it is most likely not amplified. the amp sucks anyways so bypass it if you have it with some new wires OR do like i said before and put some new speakers in it's place and run some new stuff
Old Apr 1, 2009 | 07:18 PM
  #25
zachw90's Avatar
so i would just run the wires from the speakers and splice them in with the head unit like the old ones were?
Old Apr 1, 2009 | 07:19 PM
  #26
iamsuperbleeder's Avatar
probably the most COMMON
NOTE, if your head unit doesn't have a blue/white wire, it will only have a solid blue wire, and that wire will be the amp output and/or power antenna output
Old Apr 1, 2009 | 07:20 PM
  #27
John101477's Avatar
Nice diagram!!!
one question. then you'd have two blues? light or dark?
Old Apr 1, 2009 | 07:26 PM
  #28
Originally Posted by John101477
Nice diagram!!!
no, there just wouldn't be a blue/white wire at all; just a solid blue wire to act as both the antenna output AND amp output; it will have a constant 12v while the head unit is on
and it should just be, blue... not really light or dark... I suppose dark maybe, cause some wire color's will darken with age, but's that's something I'd get mixed up with a dark purple cause I'm half color blind
Old Apr 1, 2009 | 07:36 PM
  #29
John101477's Avatar
sounds bass ackwards to me. i'd still multimeter it
hahaha I may be moving out near you bleeder. if junk don't start pickin up here i am headed to the deep south. you ever been out to hollowpaw?
brother inlaws took me last yr it was a riat
Old Apr 1, 2009 | 08:42 PM
  #30
are you serious!?! man that's all people around here do on the weekends is head out to Hollowpaw!!! I bet there's a current bulliten on myspace from one of my buddy's say'n they're gunna head out there, lol
personally, I've never been
Old Apr 2, 2009 | 05:49 AM
  #31
John101477's Avatar
Thread Jack< please excuse the interruption, your normal programing with return shortly
oh man your missin out!!! that place is sheer craze. the night we were out, some guy brought in a few strippers (never seen them cause we had a kid with us). I seen people running tires bigger than my truck. and we got so drunk my brother inlaws couldn't find due north (i am never THAT drunk lol). the wheeling was fun although suger sand sucks!!!
Old Apr 2, 2009 | 06:05 AM
  #32
YoYoMa's Avatar
Zach, If your car has a factory amp. Remove it or bypass it. Factory amps are notorious for causing issues with aftermarket heads. Also, the built in amp on that Xplod is more powerful and of higher quality than anything toy would put in their cars (with the exception of their JBL systems which still suck).
After doing this there would be no need for connecting the blue wire(s) off of the head unit.
All other connections would be made in accordance to bleeders diagram.
Old Apr 2, 2009 | 11:02 AM
  #33
John101477's Avatar
STOCK SYSTEMS SUCK...
Did you know that a brand new car with a brand new system is technically three years old? so the system in a 94 is really the technology of 91, and low end at that!!! Most speakers still use paper cones. I replace everything stock when i buy a vehicle ( except the magnum, since dodge was soooo smart and hooked it through the entire ecu... Dumb)
Easiest Install = Dodge ram
Hardest Install = Dodge magnum, second = 99 chevy impala
Old Apr 2, 2009 | 12:20 PM
  #34
zachw90's Avatar
how should i remove it and where would it be?
there's a circuit board feeding each back speaker..like open circuit board
Old Apr 2, 2009 | 01:55 PM
  #35
John101477's Avatar
the circut board it probably the amp. as i am not there to see it, that is the only reason i can see where a circut would be attached to the speaker. also i would like to note that your sony is set to run at 4ohms. the ohm loads of the JBL may be higher or lower and some manufacturers have one side at 2 and the other at 8. I would highly recommend replacing the speakers. the change in ohm load could cause your deck to work harder causing additional heat that it is not suited to handle.
Old Apr 2, 2009 | 02:09 PM
  #36
oh see now you're just trying to sound smart
Old Apr 2, 2009 | 02:18 PM
  #37
vital22re's Avatar
totally a bro
i ran all new bigger gage speaker wire to all 4 corners in my truck. and i've had no problems. Oh and i also went out and spent the 20 bucks on the harness adapter!
Old Apr 3, 2009 | 12:06 PM
  #38
zachw90's Avatar
i fixed it. i ran 16 awg lampcord as speaker wire to my back speakers from the head unit and it works fine now something with the circuit board was messing it up i think?
Old Apr 3, 2009 | 12:21 PM
  #39
John101477's Avatar
haha thanks, I think lol.
nah I was an installer for quite a while. my specialty was sub enclosures and sound quality. I could take a ragtop and make you feel like your at the concert while driving 80 down the freeway lol. all it takes is $$$. the area i live in does not use to much of the high end stuff so like most installers i was making just enough to eat. one of my buddies went to Miami and makes three times what i was.
Old Apr 3, 2009 | 03:14 PM
  #40
I used to put system's in for people every once in a while
they just say how much money they would like to put down on a system, we'd go shopping, and I'd show them what their budget could get them, and for a little $$ per component, I'd do the install
just as a hobby, nothing serious, but got a lot of electrical and wiring experience from it
