Power steering belt twisting at the bottom when engine is running
Old Apr 7, 2009 | 11:37 AM
buckz6319's Avatar
Old Apr 7, 2009 | 11:46 AM
abecedarian's Avatar
It may be the pulleys aren't lined up properly, or there isn't enough tension on the belt ... or maybe too much causing the pulleys to flex.
If you remove the belt, is there any play in the ps pump pulley, meaning if you grab the top of the pulley and push / pull it towards the front of the truck, is there any movement?
Old Apr 7, 2009 | 11:51 AM
DJ99's Avatar
I'd replace the belt, but I think your fan may be your bigger problem. On the video, it looks like it's not perfectly round or possibly broken?
Old Apr 7, 2009 | 11:57 AM
buckz6319's Avatar
Old Apr 7, 2009 | 12:01 PM
buckz6319's Avatar
Old Apr 7, 2009 | 12:07 PM
DJ99's Avatar
A couple of years ago, I thought my fan clutch was screeching. Turned out to be the belts were getting old and weren't tight enough. The fan clutch was fine. No noise since.
Old Apr 7, 2009 | 12:54 PM
buckz6319's Avatar
Old Jul 13, 2009 | 08:13 AM
buckz6319's Avatar
Still twisting and wobbling
Old Jul 16, 2009 | 03:51 AM
TNRabbit's Avatar
Did you end up replacing the belt? Looks like is stuck at some point & wore a bad spot in it....
Old Jul 16, 2009 | 02:23 PM
buckz6319's Avatar
Old Jul 16, 2009 | 05:54 PM
buckz6319's Avatar
voiddweller
19
May 2, 2016 09:10 PM
yourrealdad
7
Jul 21, 2015 08:53 AM
1badyota350
Jun 28, 2015 06:50 AM
paxanders
Jun 21, 2015 06:29 AM
