transmission question
Old Apr 5, 2009 | 04:04 PM
j0hNnI's Avatar
ummm i finished putting in me clutch couple days ago went out to put the transmission back on the motor an i cant seem to get it lined up an pushed in there though it looks perfect it just dont move lol my dad came out an he has about 35 years of experience under his belt an we both couldnt get it in there we have all the neccasary tools to do it but im not sure if theres somethin that might be catching on it which would cause it not to slide in need some insight plz
89 yoda 3vz engine
Old Apr 5, 2009 | 04:52 PM
JDMSLIK's Avatar
how far is it going in before it gets stuck
Old Apr 5, 2009 | 04:57 PM
j0hNnI's Avatar
i get it about 2 3 inches away from the motor before it just stops an wont move
Old Apr 5, 2009 | 05:24 PM
mt_goat's Avatar
That's not even close.
Old Apr 5, 2009 | 05:49 PM
jreb10's Avatar
Can we assume that you used a clutch alignment tool when you put in the new clutch?
If yes, one thing you may want to look at is the crossover pipe. It sits just above the top of the bell housing. On my 3VZE, it was low enough that the bottom seam of its heat shield caused me difficulty in separating the bell housing. It is possible that for you it could be interfering in the other direction as well. Two to three inches is about the right distance for this issue. I folded up the seam to get it out of the way. Easy to do as it is just sheet metal.
Old Apr 5, 2009 | 06:02 PM
abecedarian's Avatar
+1 on the pilot tool
but that will depend a bit on the pilot bearing....
Old Apr 6, 2009 | 07:46 AM
Windsor's Avatar
yup, and the number of splines in the clutch plate.
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
