sudden idle drop. 1989 22re
Old Apr 7, 2009 | 02:11 PM
Junkers88's Avatar
Ok I got to the house and right before I turned the rig off I glanced at the gauges and it was sitting at 450rpms. It wasn't rough and if I hadn't looked at it I never would have known. So I goose it a little and the idle returns to 450. Decide to drive it around the block and as I pull out I hear a moaning sound, like a very very faint owl, sort of a "whooooooooooooooo". Once I get out of the driveway the noise is gone, only does it in 1st and reverse, only when I'm moving very slowly and only when I'm leaving a dead stop. I made the block, came back to the house and the idle was back to normal. I took a look under the hood at the vac lines thinking it was a little leak but couldnt' find anything.
Thoughts anyone?
Old Apr 7, 2009 | 05:15 PM
Flash319's Avatar
Fan clutch grabbing?
Old Apr 7, 2009 | 05:26 PM
abecedarian's Avatar
your idle air valve started to work properly and now you can adjust the idle speed the way it's supposed to be?
mskalmus
May 28, 2017 07:51 AM
montanatruck
Feb 26, 2017 07:07 AM
kcaudill
Jul 20, 2015 12:06 PM
PlayAwhile
Jul 20, 2015 11:36 AM
