1988 4 Runner 22re engine codes
Old Apr 2, 2009 | 08:22 PM
rmd8123's Avatar
On my 88 4 runner, it wouldn't pass smog. After failing i checked engine codes, and code 8 came up and code 25 came up. Looked up code 8 and it says intake air temp sensor, where is that located. Anyone else have any ideas? Should i replace oxygen sensor?
Old Apr 2, 2009 | 08:24 PM
abecedarian's Avatar
intake air temp sensor is in the air-flow meter (on top of the air filter)
check the connectors and terminals for any corrosion or condensation and make sure the terminals are firmly seated in the plugs
Old Apr 2, 2009 | 08:25 PM
if you disconnect the plug, disconnect the battery or EFI fuse for a minute or so to clear the code, then go drive and see if the code comes back
Old Apr 3, 2009 | 08:32 PM
rmd8123's Avatar
Well i replaced the oxygen sensor drove it on the freeway, and check engine light came on then went off, checked the codes, and code 5 came up. Not sure what to check now.
JF9243176
Oct 8, 2017 04:21 AM
noahstancik
Jul 10, 2015 11:18 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
94hiluxZE
Jun 22, 2015 10:42 AM
bobbybouche
Jun 18, 2015 10:22 AM
