Gauges are in....check.
Old Apr 1, 2009 | 05:31 AM
Lotus1's Avatar
Well finally got my pod gauges in and I love them. I find that I stare at them all the time now.
I bought the pod from Jeff Mosk here…
http://www.truckpillars.com/
I initially bought a 2 pod pillar but then decided to go with a 3 pod pillar because I wanted to add a trans temp gauge to it. So I have Autometer Phantom gauges in an Oil pressure, Water temp and a Trans temp.
I initially had the red light on them. The red was really cool but in the end I decided to go with the green lights to match the dash better.
I commissioned a mechanic friend of mine to do the install. Let me tell you that was the best decision I made. I could’ve done the install myself but I just didn’t have the time to do it. It literally took him 3 days, on and off, to do the install. He did an incredibly professional install on it.
All the wires were soldered. All the connections were wrapped in heat sink. Wrapped in wire covers. Ziptied. No tape or twisty wire connectors were ever used. For the trans sensor he tapped into the trans pan drain hole. What’s cool about it is that if I want to drain the fluid I just need to unscrew
the wire off of the sensor and unscrew the center part and it drains perfectly.
Old Apr 1, 2009 | 05:36 AM
toyminator2000's Avatar
The gauges look good but I think its a dumb place to put the trans temp gauge. Looks like he used the drain plug hole.
Old Apr 1, 2009 | 07:30 AM
894x4pickup's Avatar
x2 that looks like it be the first thing to rip off on a trail.
Old Apr 1, 2009 | 08:01 AM
Lotus1's Avatar
My friend owns a machine shop and I talked to him yesterday about making a protective plate for it. lol
Old Apr 1, 2009 | 08:40 AM
Dan.3's Avatar
Originally Posted by Lotus1
Old Apr 1, 2009 | 10:44 AM
874runnersr5's Avatar
looks like that thing could get hung up on something. glad someone else realized to
Old Apr 1, 2009 | 11:31 AM
space-junk's Avatar
wow... nice lookin set of gauges there...
ive been wanting to get an a-pillar pod too because the stock gauge cluster is a little lackluster...
Old Apr 1, 2009 | 01:21 PM
iamsuperbleeder's Avatar
...No tape or twisty wire connectors were ever used...
I see tape...
but still a pretty clean install; you should see the wiring to mine, lmao
X's 3 on that trans-temp probe though!
other than that little quirk, they look good!
Old Apr 1, 2009 | 01:55 PM
Lotus1's Avatar
I see tape...
LOL. Dammit, I forgot about that tape.
Yeah, like I said in my post above I'm gonna try and get a protective gaurd for it somehow. If I can't I'll consider drilling into the side of the pan and welding the sensor in like I've seen done before. thanks
Old Apr 1, 2009 | 02:09 PM
stagger_lee's Avatar
I think they look sweet! I'm jealous.
Old Apr 1, 2009 | 03:22 PM
Jay351's Avatar
Sweet! I got the same pod, looks fantastic. I just need gauges..
Old Apr 1, 2009 | 05:27 PM
stepside trd's Avatar
Why not just drill the side of the pan and then tap the hole to accept the same threads as the plug?? Just my 2 cents....
ashamsuddin
17
Jul 22, 2024 03:59 AM
kawazx636
Oct 6, 2021 03:03 PM
zanzabar0
Oct 11, 2015 02:56 AM
Jdgarrison
Oct 1, 2015 05:22 PM
dbollier123
Sep 29, 2015 05:23 PM
