Driveshaft Delima
Old Apr 1, 2009 | 11:34 PM
94exblack's Avatar
Driveshaft Delima
I was wondering if anyone has had any experience with trying to lower the carrier bearing, to get more out of a factory driveshaft, just dont want to spend an extra 3 or 4 hundred buck if i dont have to.
Old Apr 1, 2009 | 11:50 PM
algranger's Avatar
Not sure what your asking here
Old Apr 2, 2009 | 12:50 AM
vital22re's Avatar
totally a bro
longer bolts and a bunch of washers! or make a spacer plate and use longer bolts. I'm doin the same to mine soon, i'll let you know what i do if i finish first.
Old Apr 2, 2009 | 02:00 AM
razrwild's Avatar
spacer plates and washers work just fine.
Old Apr 2, 2009 | 05:00 AM
Hypoid's Avatar
I don't know how far you can drop it without significantly misaligning the carrier. Try to keep the shaft pointed at the tcase.
Old Apr 2, 2009 | 05:38 AM
mt_goat's Avatar
I had to raise mine after I put on dual cases to reduce the angle a little. I flipped the bearing to the top of the bracket and used some washers. It's covered here on pages 11 & 12: https://www.yotatech.com/forums/f160...5/index11.html
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
ToyotaMD
Aug 17, 2018 10:16 PM
Hugh_Mann
Sep 16, 2015 03:59 AM
