Adjusting torsion bars
Old Apr 4, 2009 | 01:53 PM
Doodlebug's Avatar
The PO of my truck said he raised it by putting blocks under the rear springs and turning the torsion bars up. I'm wanting to put the truck back at stock height, but I am unsure how to adjust the torsion bars. I am hoping someone can tell me how to adjust the t-bars so that the truck would be at stock height. Also, how will I know it is at stock height? Is there a measurement somewhere that I need to take. Thanks for any help.
Old Apr 4, 2009 | 02:01 PM
Matt16's Avatar
Just turn the adjuster bolts located at the transmission crossmember. Search this one, its been covered.
He's a how-to.
http://www.off-road.com/trucks4x4/ar....jsp?id=398514
You;ll need to align afterwards. Searhc "driveway alignment" for instructions on that too.
Old Apr 4, 2009 | 02:29 PM
Cwaters1184's Avatar
im lowering mine this week as well. to to make sure, you adjust the bolt while the trucks in the air and then drop it and measure, or does it need to be driven for the new height to be accurate.
Old Apr 4, 2009 | 02:35 PM
Doodlebug's Avatar
Thanks for the link to the instructions. I noticed that is says that most trucks and 4Runners are set at the factory to about 13.5" - 14" from the top of the rim to the fender lip. Is that measurement with the truck sitting on the ground with stock tires on the rim?
Old Apr 4, 2009 | 03:56 PM
FredTJ's Avatar
Sitting on the ground, yes.
Tire size, doesn't matter.
Fred
Old Apr 4, 2009 | 04:04 PM
Doodlebug's Avatar
Thanks for the clarification. I was having a little difficulty visualizing the process. Thanks.
Old Apr 4, 2009 | 06:10 PM
Matt16's Avatar
Just don't crank it over 14" as you'll have nothing but steering problems with it if you do actually go off road.
Old Apr 4, 2009 | 06:50 PM
iamsuperbleeder's Avatar
I lawled a little at this picture in that link:
Old Apr 4, 2009 | 07:03 PM
Doodlebug's Avatar
Actually I'm trying to bring it down. I just went outside (dark) and measured and it sitting somewhere around 16", maybe a little more. Heck, I'm having steering problems just going down the highway!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
choppe777
May 16, 2016 08:00 AM
Scottcrb
Mar 3, 2016 11:57 AM
HiLuxer
Sep 9, 2015 02:43 PM
moparbay
Sep 3, 2015 12:48 PM
