Will the W50 bolt upto a 22RE?
Old Apr 7, 2009 | 07:10 PM
lilgreg46's Avatar
I have a '93 standard 2wheel 5speed with a 22RE and a W55 trans. Long story short.... My truck is a daily driver and I can not be down for repairs so looking to swap trans. I have leaned ALOT about Toy trans in the past week. Mainly every trans I have bought is not the right one. Will a W50 bolt upto a 22RE? It has a W55 in it now and from what I can tell everything "looks" close like the rear mount, slave cly ect... The bell housing is the question and the length of the input. From the info I have found both have a 21spline x 29mm input and tail shaft 21 splines. The gearbox length is the same @ 22" so the drive shaft has to be the same length. This swap is only a temp fix and not intended to be run for a extended time but only long enough for me to rebuild my W55 and get it back in there. Let me know what anyone thinks!!!!! P.S. I will have a W50 and a W56 (4wheel) trans that I will not neeed after this is over if anyone can use them.....
Old Apr 7, 2009 | 07:11 PM
ozziesironmanoffroad's Avatar
i dontthink so.... i BELIEVE the engine for the 22re is the w56.... someone correct me if im wrong
Old Apr 7, 2009 | 07:13 PM
lilgreg46's Avatar
The W56 is the 4wheel and the W55 is the 2wheel trans due to the rear housing and the output shafts being differnt but other that that they are the same
garagespace
Oct 11, 2015 10:59 AM
Sep 4, 2015 09:27 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Gone Fission
Jul 24, 2015 12:49 PM
