Oxygen Sensor help
Old Feb 24, 2016 | 07:41 PM
Chuckwild's Avatar
Oxygen Sensor help
Trying to install a 4 wire o2 sensor. I got 1987 22re motor and ecu in a 88 body 88 had a 4 wire so bought one. I was wondering if it's OK to run the 4 wire on this 88 body wire harness but I'm using in 87 ecu and motor
Old Feb 24, 2016 | 08:10 PM
yotajakes's Avatar
if the existing o2 sensor is a 4 wire then it should be a simple replacement. if its not then replace it with the same one on the truck. if you know you have an 87 motor and harness then that is what you should buy your parts for when it is related to motor and engine electrical.
Old Feb 24, 2016 | 09:24 PM
854x4's Avatar
If your using an 87 computer (89661-35070)? and engine harness with an 88 body harness then you can run a 4wire sensor but you will need to ground the heater ground wire separately for it to work. The 88 computer grounds this wire internally but since 87 used a 1 wire sensor in the manifold the computer will not ground the wire because it was not designed too.
Old Feb 25, 2016 | 06:14 AM
Chuckwild's Avatar
Thank 854 I will try that
Old Feb 25, 2016 | 07:02 AM
Chuckwild's Avatar
I got denso oxygen Sensor do know wich wire to ground
smithyboy69
Jul 7, 2023 02:22 AM
brianroland97
Jul 8, 2020 09:06 AM
Bodster3
3.4 Swaps
7
Mar 26, 2016 10:20 AM
mswierse
3.4 Swaps
Feb 23, 2016 12:40 AM
BlackStone
Feb 6, 2016 09:21 AM
