Coolant lose- bad head gasket or cracked head ?
Old 02-18-2016, 03:27 PM
gixxer's Avatar
I have a 91' 22re that leaks coolant into the top of the pistons... its hard to start every morning, but once I get it running, it runs fine . The next day its hard to start again...No over heating at all, temperature gauge barely moves past cold.., 2 of the plugs are wet when removed before starting, cylinders are wet...
Do you guys think its a cracked head or valve guide, or head gasket causing the issues ? No coolant in the oil, and it hasn't overheated or blown hoses yet. Once it gets started , takes about 6 minutes to clear out, and then it runs fine till the next day. It leaks about 2 tablespoons of coolant daily into the top of the cylinders.
Old 02-18-2016, 03:31 PM
92ehatch's Avatar
At this point it doesn't matter which.
Pull the head take it to a machine shop to check. If it's not cracked then do the headgasket and call it a day
Old 02-18-2016, 03:42 PM
gixxer's Avatar
What would it cost to have the head checked out at the machine shop ? I see heads on ebay go for like $250 complete ? Truck is only worth about $700, body is gone, but the rest is still good.
Old 02-18-2016, 03:46 PM
92ehatch's Avatar
I just dropped mine off at a machine shop. 35 to check it. 80 to check it and machine it. You will want it machined if it checks ok. That price included cleaning. This will vary, call around.
I chose a shop that was not the cheapest but price quotes i got were around the same thing. Within a few dollars anyway
Old 02-18-2016, 04:03 PM
gixxer's Avatar
Thanks for the info.....I will have to locate a machine shop that works on engines, the few that I know only fabricate stuff, and do not work on engine components around here in NJ. I might just buy a new head off ebay and gasket set, and call it a day.
Old 02-18-2016, 06:17 PM
92ehatch's Avatar
If you buy a new head do yourself a favor and get one of engnbldrs heads and not some cheap Chinese head.
Alot of carquest have machine shops. Some napa do to
abalagtas
02-25-2016 06:22 AM
theMonch
01-13-2016 07:15 AM
rybike13
12-30-2015 12:03 AM
Dirks87runner
12-21-2015 02:18 PM
frogbodman
12-13-2015 01:24 PM
Quick Reply: Coolant lose- bad head gasket or cracked head ?
