1987 Toyota Pickup Tranny noises
Old 03-22-2016, 03:46 AM
87blackyota's Avatar
Hi im new the forum. I bought my Toyota a few months ago and its slowly been being improved. Its lifted with a solid axle swap and 33s. Ive fixed almost everthing except for this noise it makes. When im driving at high speeds shifting from 4th to 5th it makes a rattle. Cant feel it through the shifter. New u joints. Nothing changed. I noticed it gets really bad the warmer it is. Weather and when the truck is warmed up. It gradually gets worse the longer I drive the truck. Any suggestions would be very aprreciative. Im tryig to make this truck function perfectly as a daily driver/weekend play toy.
Old 03-22-2016, 07:56 AM
osv
osv's Avatar
is the rear axle rotated up, pointing towards the transmission?
Old 03-22-2016, 11:08 AM
Yes it is. Im gunna disconnect the driveshaft tomorrow and run it through the gears and see if it will make the noise
Old 03-23-2016, 05:53 PM
osv
osv's Avatar
http://www.expeditionportal.com/foru...r-Beater/page8
see if your symptoms are the same as his, and check out the 4crawler link a couple of pages later on in the thread.
Old 03-24-2016, 03:15 AM
Greased up rear u joint. Noise gone. Problem a bad u joint. Weird tho . Coykd of sworn noise was coming from the transfer case
yoda711
05-13-2016 10:50 AM
Joey22r
02-23-2016 10:16 PM
Dakotaant
02-13-2016 06:51 AM
hawaiian yota 85
02-07-2016 03:10 PM
Xtracab22r
01-03-2016 04:29 PM
Quick Reply: 1987 Toyota Pickup Tranny noises
