94 3.0 overheating
Old Feb 26, 2016 | 11:39 AM
SliverFlipper's Avatar
94 3.0 overheating
I've changed the thermostat and the fan clutch twice. Had the radiator gone through and redone. If I keep the rpms up the temperature gauge will stay in the middle but as soon as I stop in traffic the temperature starts to climb. Any ideas?
Thanks, Tracy
Old Feb 28, 2016 | 06:16 PM
MrSUT's Avatar
Are you getting coolant flow? Something might be clogged in the coolant system somewhere causing the high temps.
Old Feb 28, 2016 | 07:14 PM
Coolant seems to be flowing. I jacked the front of the truck up this afternoon to make sure the system is purged and after it heated up revved ep the engine with the radiator cap off and it forced coolant out the top. I'm just not sure if the flow is enough. Changed the water pump out not too long ago and hate to think it's gone bad already.
4x4tacoma
7
Mar 30, 2016 06:36 AM
coughingskunk
Mar 9, 2016 11:27 AM
Lfazz
11
Feb 14, 2016 10:40 AM
Rapidrob
Feb 13, 2016 06:40 AM
DirtRoad93
Feb 6, 2016 04:17 PM
