Fan shroud replacement, ebay?
Old Mar 3, 2016 | 09:24 AM
Chris Parker's Avatar
Hey guys, the fan shroud is completely missing from my truck (93 V6 e/c m/t a/c), was gone when I bought it. I called the local dealership and they quoted me two different parts; 1671165031 and 1671265010 as upper and lower shrouds for a cost of $135.
I jumped online and could not find any reference to those two parts numbers, but I found this: http://www.ebay.com/itm/90-95-Toyota...9TsuzZ&vxp=mtr
Will it work? Any reason why it would list a different toyota part number but claim to fit my truck?
Thanks
Old Mar 3, 2016 | 09:54 AM
scope103's Avatar
RWD v. 4WD.
Check the part numbers here: http://www.toyotapartsoverstock.com/...671165020.html
Would it fit anyway? I have no idea (but I would be surprised). Let us know.
Old Mar 10, 2016 | 11:08 PM
CharlieHustle's Avatar
Thanks
How could you not find references for the part numbers suggested from the dealership?
http://parts.lakelandtoyota.com/p/__...671165031.html
http://parts.lakelandtoyota.com/p/__/SHROUD--FAN--NO2-!!DISCONTINUED!!/3901522/1671265010.html
The shroud is a 2 piece unit. Consists of a Main shroud and a small lip attachment. Junkyard or ebay is where I would look. The one in the link you posted should work.
Old Mar 10, 2016 | 11:35 PM
wyoming9's Avatar
Red face
I have yet to own any Toyota`s that had one of these shroud things .
Just what are they supposed to really do but keep your face from hitting the fan.
Give you more parts to lose
Old Mar 11, 2016 | 04:53 AM
combatcarl's Avatar
^this. Mine hasn't had one in...well, ever, maybe. I just keep my squishy bits out of the fan/belt area when running. Junkyard, if you absolutely HAVE to have one.
Old Mar 11, 2016 | 06:34 AM
vikecowboy's Avatar
I bought mine on Ebay and it worked fine. I added screws in it to hold the bottom piece more securely. The metal clips do not work that well.
Good Luck!
Old Mar 14, 2016 | 08:13 AM
The radiator shroud seals off the area around the radiator core to maximize the efficiency of the cooling fan. Air being pulled in by the fan is concentrated at the radiator core to extract as much heat as possible.
How well they work on a 4runner is up for debate.
Old Mar 14, 2016 | 06:05 PM
scope103's Avatar
The way to tell if the shroud makes a difference is to tow a trailer. Uphill. Slowly. In 110°F. Can your radiator and fan keep up?
Does Toyota really design to that corner case? Well, if (and only if) you have both the Auto and 4wd, you get an extra temp. sensor that will switch off the A/C when that combination makes it TOO hot.
Old Mar 16, 2016 | 05:51 PM
128keaton's Avatar
I've never had an issue without my shroud either. Never had it.
fine69
Mar 16, 2016 05:48 AM
gillesdetrail
Mar 4, 2016 11:57 AM
ZRTALPHA1
Feb 21, 2016 12:12 PM
Dakotaant
Feb 13, 2016 06:51 AM
Matthews210
Feb 5, 2016 06:27 AM
