Fan shroud replacement, ebay?
Hey guys, the fan shroud is completely missing from my truck (93 V6 e/c m/t a/c), was gone when I bought it. I called the local dealership and they quoted me two different parts; 1671165031 and 1671265010 as upper and lower shrouds for a cost of $135.
I jumped online and could not find any reference to those two parts numbers, but I found this: http://www.ebay.com/itm/90-95-Toyota...9TsuzZ&vxp=mtr
Will it work? Any reason why it would list a different toyota part number but claim to fit my truck?
Thanks
Thanks
RWD v. 4WD.
Check the part numbers here: http://www.toyotapartsoverstock.com/...671165020.html
Would it fit anyway? I have no idea (but I would be surprised). Let us know.
Thanks
Thanks
http://parts.lakelandtoyota.com/p/__...671165031.html
http://parts.lakelandtoyota.com/p/__/SHROUD--FAN--NO2-!!DISCONTINUED!!/3901522/1671265010.html
The shroud is a 2 piece unit. Consists of a Main shroud and a small lip attachment. Junkyard or ebay is where I would look. The one in the link you posted should work.
I have yet to own any Toyota`s that had one of these shroud things .
Just what are they supposed to really do but keep your face from hitting the fan.
Give you more parts to lose
How well they work on a 4runner is up for debate.
The way to tell if the shroud makes a difference is to tow a trailer. Uphill. Slowly. In 110°F. Can your radiator and fan keep up?
Does Toyota really design to that corner case? Well, if (and only if) you have both the Auto and 4wd, you get an extra temp. sensor that will switch off the A/C when that combination makes it TOO hot.
ZRTALPHA1
Feb 21, 2016 12:12 PM
