No start issue need help ASAP
Old Mar 3, 2016 | 11:12 AM
4by4yoter's Avatar
Okay so I need to leave the state in 2 days and now my truck wont start I need some serious help. I paid a guy to Connect a trailer wiring harness to my truck so I can rent a trailer from uhaul. On the test light both turn signals work but brake lights dont. I took off the tail light to see the brown wire (tail lights) wasnt even spliced into the brake light bulb wire. So I spliced it into the hot wire. red(stop) wire is already spliced into the other. Brake lights now work on the test light but the car will not start I ACCIDENTALLY left the headlight switch on when splicing the brown tail light wire into the brake light bulb wire. The car will not start. Extreme flickering of lights in the cab. I undid the brown wire and it stopped flicking but still no start. Just clicking. ALL FUSES ARE GOOD. Is this no start issue unrelated or did leaving the head light switch on fry the ecu or what is going on? Wont start with the battery charger on it either. What could have happened? Should I try a different battery since i did strain it last night testing my lights quite a bit or should it still start with the battery charger? It was reading full but now only half charged
Old Mar 3, 2016 | 12:05 PM
scope103's Avatar
You won't get useful help until you describe the problem.
Turn the key - click (relay) - clunk (solenoid) - rrrrr (starter) - bang, bop, boop (firing) - chug-a-chug-a-CHUG(starting) - hmmmmm(running) - clonk, bank (stopping).
Where is yours?
"ALL FUSES ARE GOOD." No they're not. You don't even know where all the fuses are. Which ones did you check (and how)?
Old Mar 3, 2016 | 12:13 PM
4by4yoter's Avatar
Where is yours?
Lol I know exactly where every fuse and relay is and their exact purpose. It was clicking. Apparently leaving the headlight on while splicing wires messed up the battery or it just randomly fried itself. I put in a different battery and jumpstarted it and it started right up.
Dustin Egle
Mar 4, 2016 09:47 AM
Matt944
Dec 29, 2015 08:16 AM
Yotapower01
Dec 29, 2015 01:58 AM
tnjzx
Dec 22, 2015 04:27 PM
Mason King
Dec 16, 2015 12:29 AM
