Exhaust Question
Old Apr 10, 2008 | 06:35 PM
Strings's Avatar
Exhaust Question
I have a 94 DLX with a 3.0 and I want to run a exhaust that goes through a High Flow Cat and then "Y's" into two Flowmaster Super 40's and then out under the bumper with dual tips. My question is what size tubing, cat, ect. should i use?
Old Apr 10, 2008 | 06:41 PM
norcalsvx's Avatar
maybe 2.5" cat to 2" pipes
Old Apr 10, 2008 | 06:45 PM
Strings's Avatar
I was hoping to keep it all one size and i've been thinking either 2.25 or 2.5. Any Opinions?
Old Apr 10, 2008 | 07:00 PM
Noltz's Avatar
Single cat w/dual mufflers is a waste of money. Get a Super 40 2½" in w/dual outs (usually 2¼", iirc), and have the shop fab you a cross-pipe.
Now, if you went full duals, that's another story
Old Apr 10, 2008 | 07:17 PM
stupid_mud_gremlins's Avatar
When I had my manifolds off the heads, it looked a lot like you could flip the right (passenger side) one over and use it on the driver's... anyone tried this for s**** and giggles? Might be an easy way to do full dual exhaust if it works. I should have tried it while everything was apart...
Old Apr 10, 2008 | 07:32 PM
FredTJ's Avatar
Couple of points:
- I wouldn't bother with a "hi-flow" cat. OEM flows plenty.
- I wouldn't go any larger diameter that OEM.
Larger diameter = less velocity.
Less velocity does not = something better.
Less velocity is not a good thing.
You're 3.0 doesn't flow any volume to speak of.
Hell, a gnat fart pass more "gas" than these engines
Fred
Old Apr 10, 2008 | 07:40 PM
iamsuperbleeder's Avatar
Old Apr 11, 2008 | 03:11 AM
Strings's Avatar
I was going with too seperate Flowmasters because I thought It might sound a little more aggressive but would it sound better? What is the stock size exhaust?
Old Apr 11, 2008 | 04:31 PM
Jay351's Avatar
2 1/8" is approx the stock pipe size for the 3vze. Step it to 2.25" for ease of availability. I wouldnt go duels. Just go with 2.25" cat, muffler then end it with a boom tube or somthing. I put a 3" one on my truck for fun and it actually sounded alot deeper.
tj884Rdlx
Aug 28, 2015 12:04 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
thefishguy77
Jul 30, 2015 10:59 AM
Coreyr384
Jul 10, 2015 11:13 AM
