Anyone install a new upper ball joint lately?
Old Apr 17, 2008 | 04:15 PM
Cyberman's Avatar
If so, how do you put the "bolts" through the ball joint? I'm going to assume that they need pressed in, but is there another way?
Old Apr 17, 2008 | 04:21 PM
steverwrx's Avatar
I just put in new upper ball joints and spacers. Not sure what you are asking. The ball joint should have the studs(bolts) already attached. I had to tap mine out and use the longer versions with the spacer kit. If they are not attached, just tap them in with a small hammer or something.
Old Apr 17, 2008 | 04:26 PM
Cyberman's Avatar
The studs are not attached. They have splines that hold them in place. Tried a hammer, to no avail.
Old Apr 17, 2008 | 04:31 PM
pat24's Avatar
if you are to but the bolt through the holes is it enough to put a nut on it maybe bull the bolt in place while tightening ?
Old Apr 17, 2008 | 04:36 PM
Cyberman's Avatar
I thought about that, but the stud won't clear the upper control arm to put a nut on. I don't have a vice to hold it and try that either.
Old Apr 17, 2008 | 04:42 PM
RustBucket's Avatar
So is your problem getting studs out of an old balljoint or putting studs into a new balljoint?
Old Apr 17, 2008 | 04:43 PM
RobD's Avatar
If they're not going in because they're too tight, try putting the studs (bolts) in the freezer for a few hours.
Old Apr 17, 2008 | 04:51 PM
Cyberman's Avatar
hmmm... might work
Maybe this is my reason to get spacers. Although I don't really think I need them along with a 4" lift, or should I?
Old Apr 26, 2008 | 06:12 AM
pat24's Avatar
do it up bj spacers was one of my best investments
Old Apr 26, 2008 | 06:20 AM
RobD's Avatar
Sorry, I have no lift, so I can be of no assistance.
Old Apr 27, 2008 | 06:38 PM
Cyberman's Avatar
I resolved my issue by getting some allen bolts, nuts, and nylock nuts to keep the regular nuts from getting loose.
I also ran into a similar issue with rear brake shoes. There are a pair of studs that go in to mount the adjuster. Those had spines as well. I tried the freezer trick, no good. I ended up grinding the spines off with a Dremel.
Old Apr 27, 2008 | 09:21 PM
RobD's Avatar
Thought the freezer might help. My brother has to freeze sleeves before inserting them into a block. Mind you, he's sleeving Cat engines.
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
KyleT
Jul 21, 2015 07:54 PM
ksmudrunner99
Jul 21, 2015 05:33 AM
