22re no start after compression check
Old Apr 8, 2008 | 07:36 PM
91Toyota's Avatar
Checked my compression on #3 cylinder and while I was cranking I saw some sparks. I stopped, looked at my compression and came back later to start it and it will not start. It just turns over. I don't know if I have spark or fuel. I checked all the important fuses and found nothing. I think I fried some piece of crap sensor. What do you think?
Old Apr 8, 2008 | 07:39 PM
jason191918's Avatar
Check for spark.
Old Apr 8, 2008 | 07:48 PM
91Toyota's Avatar
No check engine light. I tried checking for spark out of the coil with a screw driver out of the wire and grounded to the engine but I could not see it. I will try to get my bro to help...but I am thinking I f'd up my coil
Old Apr 8, 2008 | 08:50 PM
91Toyota's Avatar
Update...there is no spark
So is it my coil?
Old Apr 8, 2008 | 08:58 PM
iamsuperbleeder's Avatar
hopefully just the coil and not the module above it... that's kinda pricey; did you test to see if you're getting power to the coil?
Old Apr 8, 2008 | 09:54 PM
91Toyota's Avatar
Nope...did not test it at all but its FIXED!!!
After looking at MORE fuses...I found out that the 30 amp fuse (block shaped (odd)) was blown. I jumped that and it started right up. Too late to get the fuse now so it looks like I will be riding my motorcycle in the morning...lol
Old Apr 13, 2008 | 09:00 PM
84sr5yoty's Avatar
You're supposed to ground the coil wire when checking compression. This is probably why you blew a fuse.
PureTacoma_Tundra
PureTacoma_Tundra
Jul 2, 2015 12:35 PM
MRael
19
Jul 13, 2002 08:54 AM
jacksonpt
Jun 17, 2002 09:47 AM
