1995 22re... coolant in oil.
Old Apr 8, 2008 | 10:49 PM
Squeebs's Avatar
My buddy has a 2wd pup with the 4 banger... he has coolant in his oil and is convinced that it is his head gasket... im not.
it starts up, runs like a parapalegic... But no white smoke from under the hood.
Any other ways these engines have been known to let coolant into the oil?
Old Apr 8, 2008 | 10:54 PM
thook's Avatar
The timing chain can wear through the timing cover on the driver's side. Behind that area of the cover is a coolant passage coming from the water pump. So, yeah....in this case no coolant would entering the combustion chambers....just damaging the bearings.
Old Apr 9, 2008 | 07:22 AM
eric-the-red's Avatar
I would confirm the headgasket theory with compression and leakdown tests before tearing into the engine.
Old Apr 9, 2008 | 07:47 AM
CJM's Avatar
CJM
Coolant in oil means the HG. Period..
Old Apr 9, 2008 | 08:45 AM
thook's Avatar
No.....it doesn't. On a V6....certainly. But, the 22re can be just the timing cover.
Old Apr 9, 2008 | 12:06 PM
Slowstrike's Avatar
22re coolant in oil = timing chain rub thru. My bet is that when you open it up the driver side guide is eaten through or fell into the oilpan.
Longbed 90
Mar 11, 2019 12:38 PM
JUICE222
Oct 13, 2015 08:50 AM
viesail
Sep 21, 2015 06:00 AM
Boomer8404
Sep 20, 2015 06:15 PM
LotOMiles
Sep 14, 2015 11:45 PM
