90 4runner blowing turn signal fuses
so the other day i was driving the 90 4runner and went to change lanes and turned on the signal it flashed then all of a sudden stopped i pulled over looked at fuse sure enough it was blown then i put a new one in and i turn the signal on again and about 30 seconds into flashing it blows again and i repeat same thing obviously i have a short somewhere but where?
thanks for any and all help
just a thought...check this thread out...I had problems last year with my signals blowing fuses...
https://www.yotatech.com/forums/f131...inking-116763/
so any ideas where i should look now when i put in a fuse the hazards dont work at all should i look there first? also the horn doesnt work? is all this on the same circuit?
if it intermittently blows fuses in the future...reread that link I sent earlier. Hopefully this was just a fluke, but mine was 2 loose ground wires, so they worked for a while, then *poof*....another fuse. Hopefully you squished the gremlin.
06-01-2021 01:51 PM
Suprarossa
07-06-2015 05:21 AM
