Yet another knock sensor question
Old Apr 15, 2008 | 05:40 AM
Team420's Avatar
I hate to keep beating this dead horse, but i have not been able to find an answer so... I get code 52... usualy after i get truckin down the road a mile or so, sometimes it comes on as soon as i throw her in gear. I changed the wire, and still get the code..i know i need to do some soldering and such to the other end of the wire..my question is, if i disconnect the sensor all together shouldnt my cel come on after 3 sec? would it indicate a faulty ecu if it does not come on till i get down the road? Thanks
Old Apr 16, 2008 | 05:07 AM
Team420's Avatar
doesn't anybody have an idea?? Or is everyone just sick of answering knock sensor questions.. im at the end of my rope with this thing.. i soldered the wires up real good to no avail.. still does the same thing, makes no difference if the harness is connected or not!!
Old Apr 16, 2008 | 06:59 AM
swerks's Avatar
I know its rare but maybe you need to replace the sensor itself ??? I have been having knock sensor issues myself that I have yet to figure out.
Old Apr 16, 2008 | 11:11 AM
Team420's Avatar
Question
thats what im startin to think... but i dont wanna spend $180 on a sensor if its not gonna work... i just wanna know if its normal that the cel dont come on till i get down the road a bit, even if the sensor is not connected, doesnt make sense, does it not listen for knock at idle? i can let it idle for an hour, still no light...once i get a mile or 2 down the road..it pops on...makes no diff if the sensor is hooked up or not.
Old Apr 16, 2008 | 11:48 AM
dcg9381's Avatar
Generally, it's hard for KS to go bad.. Now I know this is a common issue on the3 3.0 trucks - so you might search or wait for some feedback.
There seems to be "test circuitry" that validates that the sensor is connected. Disconnecting it won't solve your problem.
There is no knock at idle. It's generally an under-load condition.
Old Apr 16, 2008 | 12:18 PM
swerks's Avatar
My cel comes on at about 3000 rpm every time ??????
Old Apr 16, 2008 | 12:43 PM
Team420's Avatar
have you changed your wire yet?
thats what mine usually does...only when under load tho, i can rev to 4,000 rpm in neutral and it doesnt come on..in my case; my harness(ecu side) looks nasty, and the wires pull out easily, hoping dirtoyboy can hook me up with a new one, and that it'll fix my prob, .... if not..guess ill b gettin in there AGAIN to change the sensor(prob should have done that to begin with!!!)
Old Apr 16, 2008 | 02:11 PM
spaugh's Avatar
toyota ECU's don't use the knock sensor until after 3000 RPMs. You sensor could be putting out crap and the ECU won't know until the truck revs to 3K.
Old Apr 16, 2008 | 02:32 PM
Team420's Avatar
ok...thank you.. that answers my question.. although my cel usually comes on long before 3k.. i try no to get it up that high when accelerating..And now i have another question.. tonight i get into my truck and the cel comes on at startup... pulled the code got 71..egr gas temp.. at first i would think this is normal from the high egt's, however in the haynes it says this code is for gas temps being low, or a bad temp sensor... coincidence? or did i misunderstand the effects of knock retard? it was my understanding that retarded timing = high egt's
Old Apr 16, 2008 | 03:31 PM
Team420's Avatar
do these symptoms sound like an ecu problem...im startin to get real confused about all this
Old Apr 21, 2008 | 12:50 PM
rdlsz24's Avatar
What exactly does a knock sensor do? I don't believe mine is hooked up on my truck lol.
Rob
Old Apr 21, 2008 | 02:01 PM
Team420's Avatar
It "listens" for engine knock, and retards timing, to correct it... it is fairly important, and if not working your truck will run in "safe mode" ... thus retarding your timing to zero = less power, decreased fuel economy(in my case drastic), and higher egt's which can lead to other problems.
tj884Rdlx
Aug 28, 2015 12:04 PM
nonstop
Jul 24, 2015 06:29 PM
keithporter83
Jul 18, 2015 12:37 PM
88yodabasket
Jul 13, 2015 01:32 PM
smiley52
Jul 11, 2015 05:16 AM
