Installing A New Cam
Old Apr 13, 2008 | 05:42 PM
myyota's Avatar
Im thinking of getting a new cam for my 86 4Runner, i was thinking of the engine builder 261c cam and a downey header. will i see noticable gains with this set up ?, and what about the exhaust, what size pipe should i use 2.25 or 2.50 ?. How hard is it to change a cam, is it just a matter of unbolting the old cam and putting in the new cam and readjusting everything ?.
Old Apr 13, 2008 | 06:02 PM
javadoody's Avatar
start here: https://www.yotatech.com/forums/f116...at-cam-140879/
2.25
not hard. but unless you are truly gifted, you should replace the head gasket. and check the timing chain + guides.
Old Apr 13, 2008 | 07:12 PM
nmtoy's Avatar
The 261 is the cam I want also. How many of you guys with new cams replaced your rocker arms? I know Roger Brown recommends it and it seems like a good idea.
Robb
Old Apr 14, 2008 | 10:38 AM
norcalsvx's Avatar
i run the 261 w/ a new head but i love it
Old Apr 14, 2008 | 11:00 AM
dirtoyboy's Avatar
I have the same cam, header and engine.....
power gains were negligible but noticeable........it sounds really cool though!
Old Apr 14, 2008 | 05:35 PM
javadoody's Avatar
Robb
i think that would depend on how high the mileage. i didn't, but then there is only 64k on it when i installed the cam.
Old Apr 14, 2008 | 07:11 PM
InternetRoadkill's Avatar
Absolutely replace the rocker arms when installing a new cam. Only use OEM toyota rockers.
Old Apr 14, 2008 | 10:10 PM
Pistonman's Avatar
I have reused rockers , IF they are in good condition. No abnormal wear, no eaten cam lobes, etc. I break the glaze on them with a very fine emery cloth, then polish with some scotchbrite, by hand usually on glass or a flat surface. I have mic'd the shafts, the rocker bores, etc. The FSM outlines the measurement details.
bigjstang
Jun 2, 2025 03:56 PM
RatOmeter
Oct 22, 2015 03:17 PM
nonstop
7
Aug 11, 2015 09:26 AM
daddio
Aug 9, 2015 07:17 PM
Fakayayou
Aug 9, 2015 12:47 AM
