rear suspension ??
Old Apr 9, 2008 | 02:14 PM
4x4YOTA's Avatar
rear suspension ??
ok so I have a BJ spacer up front and my t-bars are tweaked so Im sitting at 15" fender to rim and I have an add-a-leaf in the rear and my rear is still sagging and I was wondering what the best/cheapest way to get it close to level I was thinking a shackle has anyone run the shackle from pep boys its 5/16" x 1.5" with holes at 4", 6", 8" (center bolt hole to center bolt hole)
Old Apr 9, 2008 | 03:08 PM
just a 22re's Avatar
no but how much are these cause now i wanna go and take a look and if you have a part number to thanks man
Old Apr 9, 2008 | 03:10 PM
norcalsvx's Avatar
some people run jeep coils in the rear (cheap) there is a thread in here somewhere
4x4YOTA's Avatar
there $14.99 and sorry no part number
auto zone has them as well for $13.99
http://www.autozone.com/selectedZip,.../selectZip.htm
Old Apr 9, 2008 | 03:29 PM
BigWavePaul's Avatar
Arrow eBay some shackles, 2" lift, durable & cheap too
The AutoZone shackle doesn't look offset or dependable, seeing as you intend on taking this pickup on the highway.
The greaseable shackles that I have on eBay are just what you need. I didn't bother installing them and after having them around for too long, I'm offering them up to the highest bidder.
Thread for shackles, Daystar 89-95 4WD 2" Lift
eBay Daystar 2" Lift Shackles, 40% off manufacturer's price, and new too
Old Apr 9, 2008 | 04:14 PM
norcalsvx's Avatar
https://www.yotatech.com/forums/f116...ations-134626/
Old Apr 9, 2008 | 05:53 PM
4x4YOTA's Avatar
and what will that do ?
Old Apr 9, 2008 | 09:03 PM
norcalsvx's Avatar
it will lift the rear
Old Apr 9, 2008 | 09:07 PM
sleaz22xx's Avatar
Thats hooded out IMHO
4x4YOTA's Avatar
but I already have a add-a-leaf will it still give me more on top of that?
Old Apr 9, 2008 | 09:24 PM
norcalsvx's Avatar
i would'nt do it but i run 33x10.50 w/ all stock rear susp. and it very rarely rubs
Old Apr 9, 2008 | 09:27 PM
4x4YOTA's Avatar
Im runnin 33x9.50 and dont rub any but my rear is still saggy and I I want it to sit level so it looks proper
Old Apr 9, 2008 | 09:32 PM
4x4YOTA's Avatar
I most likely wont do it cuz I want to get travel out of my rear and that will limit it worst I would like to just do a 63" chevy swap but I lack the welder to do so. so if any body in Colorado springs has a welder and would help me please I would appreciate it thanks!
Old Apr 9, 2008 | 09:34 PM
4x4YOTA's Avatar
hey "norcalsvx" I noticed in your thread about your truck you have a one piece drive shaft compared to the stock 2 piece how does that work does it change any thing or is it just something you did?
Old Apr 10, 2008 | 08:30 AM
norcalsvx's Avatar
it works fine and it is a lot lighter than the 2 piece, i had it made at a local driveshaft shop because my old one was shot-
63 chevies would be the way to go if you can find a welder-
Old Apr 10, 2008 | 09:45 AM
mr x's Avatar
I'm in the same boat, I'll probably just get some cheap shackles.
Old Apr 10, 2008 | 10:49 AM
AxleIke's Avatar
Shackes are cheap, and easy, and are a 1 hour job, if you don't have too much rust.
The coil spring mod is okay, but not my thing. They seem to work well, but I've heard they limit flex.
Best bet would be to ditch the AAL's, and put the truck on the ground. Figure out how many inches you need to go up to get the rear to match the front. Then double that number, and buy shackles of that length. So, if you need to go up 2 inches, you need a 4" shackle.
This will give you the best performance for the least money.
Old Apr 10, 2008 | 10:50 AM
AxleIke's Avatar
What does that mean? Pardon a guy who doesn't follow slang.
Old Apr 10, 2008 | 11:19 AM
norcalsvx's Avatar
hooded out means that it is ghetto (cheap/weak/lame)
Old Apr 10, 2008 | 12:15 PM
AxleIke's Avatar
Oh. So gangster speak then. You kids.
