passed smog, then engine light on?
Old Apr 12, 2008 | 04:41 PM
skinnyhb's Avatar
i just got back from passing smog, and on the way home i got a check engine light. i pulled the codes and got a "open or shorted air flow meter" code and an "open or shorted 02 sensor" code.
i just put in a new o2 sensor a few days ago. is this my culprit? my truck passed smog with flying colors.
Old Apr 12, 2008 | 04:51 PM
skinnyhb's Avatar
additional question, can i drive the vehicle like this if it seems to be running fine?
Old Apr 12, 2008 | 05:05 PM
blakegeee's Avatar
When I got my last emission test on a Dodge Ram the check engine light came on and the guy said that is pretty common for vehicles to do that while being tested. I guess the test simulates a steady incline and it is fairly strenuous on the vehicle.
I'd reset the code, then see if it ever comes up again. If it doesn't come up again, than you should be fine.
Old Apr 12, 2008 | 05:13 PM
skinnyhb's Avatar
interesting. i wondered if perhaps all the weird tests and stuff would throw something off in there. i reset the ecu. however, should i assume that it is my 02 sensor if it comes up again.
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
Johntom240
7
Jul 13, 2015 12:18 AM
timmJ
Jul 7, 2015 02:01 PM
