Shorted something out in my truck.
Old Apr 14, 2008 | 12:32 PM
SLOWBOOST's Avatar
Long story short, I was wrapping up my 5spd swap and got to the electrical part of the mess. I am still using the auto ecu, when I was jumping wires on the park switch to see which combo was needed to start, something shorted out and now I just get a battery light on the dash and no other lights. The windows do not work, locks, radio, lights all work though. I checked relays and fuses I could find, but they all checked out all right. Does anyone have any ideas on what this could be. ......This is all before I got the idea to just take the park switch off the auto trans and lock it into position temporarily so that I could still drive my truck.
Old Apr 14, 2008 | 01:02 PM
thook's Avatar
If you've verified you have voltage at the EFI fuse, voltage past that to the main relay, that the relay works, and that voltage then gets to the ECU....then, I believe you've pooched the ECU. (No CEL light would indicate either no voltage to the ECU or that it's no longer working.)
Old Apr 14, 2008 | 01:59 PM
SLOWBOOST's Avatar
yep. that was my suspicions too. thanks for the post...im burnt out after doing the whole swap in a day.
Old Apr 14, 2008 | 02:04 PM
thook's Avatar
Sorry to hear that. When you refreshened your spirits a bit, go ahead and test the ECU for voltage and at the ignition terminals....(#10-EO1 and #20-EO2 w/ ignition switch on). The ECU procedure is in the FSM ( http://personal.utulsa.edu/~nathan-b...e/102engin.pdf )...uh, there...
If it fails the testing, look around the YT classifieds. I found a good used one for my '92......$50.
Jayboy74
10
Dec 21, 2021 08:27 AM
jasonty
41
Dec 23, 2018 01:00 PM
izzmee
Aug 17, 2015 10:20 AM
smooretahoe
Aug 14, 2015 09:23 AM
v_man
Jul 23, 2015 04:01 PM
