new knock sensor thread, Please look and give advice
Old Apr 17, 2008 | 12:27 PM
Team420's Avatar
I will start from the beginning.. got code 52 a while back, after countless hours of research i finally got the balls to change the wire going under the intake... got her all back together, and still code 52.. so i started checking out the other wire going back to the ecm.. noticed it looked nasty...so i got a new section of wire with the connector of another truck, soldered it up real good, taped her up real good, still code 52... So now i dont know what to do.. i really wanna rule everything else out before i blow $170 on a new sensor and have to rip it all apart yet again. i put an ohms tester on the wire i spliced.. read 3.29... definitely continuity... put it on the new wire goin to the sensor and i get no reading... should there be continuity to the sensor? is the reading stated above ok for the harness to ecu? I am running out of ideas here, i would figure there should be continuity to the sensor, but others have said the only way to test that is with an oscilliscope or something? So now i am lost.. should i just buy the sensor rip it all apart again, and hope it fixes my problem? or could i still have a bad connection? HELP.. im running out of beer and money
Old Apr 17, 2008 | 12:36 PM
Blurr's Avatar
just checking but did you disconnect the battery to clear the CEL after replacing your wiring?
Old Apr 17, 2008 | 12:41 PM
Team420's Avatar
yes... i did...sorry should have mentioned that... i have done alot of research..and im pretty sure i did everything by the book...
Old Apr 17, 2008 | 02:39 PM
Team420's Avatar
Also.. i was wondering.. is there a way to check that there is signal getting to the knock sensor..like using multi meter to check for power at the harness? at least if i know im getting power at the harness.. ill know it has to be the sensor....right? i know its only a millivolt circuit.. do i need a special tester for this.. or will a cheapo multimeter do the trick? i have been racking my brain on this for nearly 2 weeks now!!
Old Apr 18, 2008 | 05:03 PM
Team420's Avatar
bump for a response
Old Apr 19, 2008 | 08:54 AM
just a 22re's Avatar
a milti meter is fine
Old Apr 19, 2008 | 12:18 PM
Team420's Avatar
so if i test continuity to ks i should have a reading...right? mine does nothing.. indication of bad ks.. or no complet cicuit to ks from connector? thanks for the reply!!
Old Apr 20, 2008 | 08:13 AM
Team420's Avatar
bumped again...sorry
Old Apr 20, 2008 | 08:25 AM
Team420's Avatar
Check this link out.. it could be helpful to a lot of people. however.. it didnt answer my question about continuity to the knock sensor..any thoughts?
http://www.supras.com/06/techcenter/display.php?QID=69
Old Apr 20, 2008 | 09:24 AM
DeathCougar's Avatar
Did you replace the knock sensor?
Old Apr 20, 2008 | 09:53 AM
Team420's Avatar
no..i did not replace the sensor itself...just the $12 wire(i have been told over and over again that the sensor almost never fails)...im just not sure if there should be continuity to the sensor or not, if i can rule out the wiring as my problem...ill gladly get a new sensor...otherwise..i'd rather not spend the money on a sensor that cannot be returned
Old Apr 20, 2008 | 11:14 AM
Yoda's Avatar
I don't believe there is a signal TO the knock sensor. The knock sensor generates a signal when it detects a knock. They do go bad.
There is also an early and later style knock sensor and harness
Old Apr 20, 2008 | 01:55 PM
Team420's Avatar
yes...sorry...the signal comes from the sensor..and i found out the hard way about the different styles for different years, i just cant figure out if there should be continuity between the connector and the sensor.. i would think there should be, but have not yet been able to confirm it.
Old Apr 20, 2008 | 02:14 PM
aaron's Avatar
hey where do you find what code means what??
Old Apr 20, 2008 | 02:32 PM
scuba's Avatar
Old Apr 20, 2008 | 02:38 PM
Team420's Avatar
the haynes, chiltons or mitchels would have it..search yt for the code you have or ...the last one is real obvious!!
aaron's Avatar
Originally Posted by scuba
lol tried that i can only find select codes not a whole listing of all of them?
Old Apr 20, 2008 | 02:39 PM
aaron's Avatar
ok helpful thanks
Old Apr 20, 2008 | 02:40 PM
Team420's Avatar
what code do u have?
Old Apr 20, 2008 | 02:42 PM
aaron's Avatar
im going outside to find out now
