Spedometer Problem ( I think) and searched
Old Apr 8, 2008 | 04:28 PM
nm4runner's Avatar
Question Spedometer Problem ( I think) and searched
Hi Guys...I have 1995 4runner, 3.0 168k miles 2wd(I know, but gas mileage is pretty good). Today out of the blue the speedometer doesnt work. It had the normal make funny sound until warmed up but I just thought it needed lube, today nothing at all. The car seems to shift fine etc.. I searched but couldnt find an answer. What should I check and where might it be located. I teach 5th grade so I like pics. The tach works fine as do all the other guages. Any ideas as well as cost. For you denver folks I just recieved a coupon for 25% off any part as well as 10 % off all parts for trucks with more than 60k miles ( just an fyi)
Old Apr 8, 2008 | 05:50 PM
machabees's Avatar
You probably have to open up your gauge cluster and take a look at the gears inside. someone correct me if I'm wrong but I don't believe the speedo is cable driven in these trucks. which means the problem is either in the electrical connection between the dash and the pickup unit. or a broken gear inside the gauge cluster.
Old Apr 8, 2008 | 06:31 PM
Matt16's Avatar
Undo the speedo cable from the transfer case and feed it towards the engine. That way its loose enough to undo once you pull out the instrument panel.
Old Apr 8, 2008 | 06:53 PM
machabees's Avatar
So the Speedometer is cable driven. My bad.
Old Apr 8, 2008 | 07:04 PM
nm4runner's Avatar
so should i replace this cable and how hard is it...also have a pic of the cable. how much are these cables...i have the 25% coupon i was thinking of replacing the o2 sensor maybe not...anyone know a good mechanic in denver metro area....
Old Apr 8, 2008 | 07:07 PM
machabees's Avatar
before you decide whether or not to replace the cable you need to pull that cluster out and make sure it's actually connected. the cable isn't necessarily your problem. though it certainly could be.
pull out your cluster and try and turn the speedo by hand.
that will help you determine if your cables bad or if the problem is inside the cluster.
Old Apr 8, 2008 | 07:35 PM
nm4runner's Avatar
ok I pulled out the cable i think, big plug behind cluset, it turns has some kind of lubricant or graphite but it turned, so it might be cluster, guess I need to look for pull aparts btw pulling the cluster is a major pain in the but....
Old Apr 8, 2008 | 08:43 PM
dr-dirt's Avatar
in my old 85 4x4 p.u. my speedo did the same thing, and now my 91 is starting to do it too, what my problem was is that the gear connected to the speedo cable inside the cluster develops a crack in it and the cable/gear starts to slip.
Old Apr 9, 2008 | 10:53 AM
nm4runner's Avatar
bump for the day crew--anyone know a good upull it yard in denver metro area.
Old Apr 9, 2008 | 11:05 AM
Flash319's Avatar
Unplug from trans and have a look. The gears in there are plastic and could get damaged easily. I thought everything after 90 or so was electric. Guess not in 2Wd's
Old Apr 9, 2008 | 02:27 PM
nm4runner's Avatar
Update...after reading through numerous topics i went and checked some thing i think is called vss or something. i unscrewed this circle connector which is located just before the drive shaft. inside was a pin thingy(remember 5th grade teacher here looked like a spring at the end of it. is the pin thing supposed to come out or did mine snap not sure..i can take pics if that might help..also any pull a parts around the denver metro area with 2nd gen 4runners
Old Apr 10, 2008 | 07:12 AM
nm4runner's Avatar
any idea on my previous post about the sensor/pin thingy...
Old Apr 10, 2008 | 12:29 PM
anotherjeff's Avatar
"VSS" = Vehicle Speed Sensor? Apparently, '95 4Rnr's have an electronic speed sensor on the tailshaft of the tranny. They also have a speedometer cable.
Do you have the FSM?
Old Apr 10, 2008 | 02:04 PM
nm4runner's Avatar
I have the one that is available for download, ill go check it out. I am leaning towards a busted speedometer cable.
Yota.Jay
Jul 23, 2015 08:08 PM
Poppie51
Jul 16, 2015 06:16 PM
Fundy Rider
Jul 16, 2015 01:35 AM
trd4runner
Jul 14, 2015 05:16 PM
wilbertd
Jul 6, 2015 07:39 AM
