which pickup tailgate fits 90-95 runner?
Old Apr 16, 2008 | 01:51 PM
bigt's Avatar
which pickup tail gate can i use to replace the rusted window gate on my 93 4runner to a pickup truck... or is this not possible??? i dont want a window and would like the ease of use of pickup gate
Old Apr 16, 2008 | 02:22 PM
4Runner202020's Avatar
so you want just the pickup gate and no upper window piece... i'm sure it could me done but a lot of cutting probably...
Old Apr 16, 2008 | 02:30 PM
bigt's Avatar
yes i want to put a pickup trucks .. gate on my runner.. since they are the same frame i was thinking the same year would fit or is it too narrow at the top?
its for a trail rig btw
Old Apr 16, 2008 | 02:31 PM
tc's Avatar
tc
I think the width will match up - as you said, the frame and a lot of the body is the same, the problem will be the hinges and latches.
Old Apr 16, 2008 | 02:32 PM
machabees's Avatar
Why don't you just roll the window down and lave it down. WOUILA pickup truck.
bigt's Avatar
hrmm yeah see maybe i can gind someone with a pickup by me and try this out.... i tihnk i know someone with a 2wd same year...
cuz the gate is rusty to hell and the window is stuck up and not even power to the motor directly will make it budge just smokes the motor
Old Apr 16, 2008 | 02:33 PM
ya you might be able to snag the hinges and mounting points for them off the pickup when you get it and do a little cuttin and fab and get them to work...
Old Apr 16, 2008 | 03:38 PM
4x4phil's Avatar
I would just bust out your rear window.......LOL just kidding...kind of.
I would just find a 4-runner rear gate and take the window out, there u go, or just leave the window down like someone said. but it would be cold with out a window.
it would be a lot easier then trying to fab something up.
Or you could just bob the rear, leave it open....LOL and make a canopy/cover
Old Apr 16, 2008 | 04:05 PM
Noltz's Avatar
Since you're gonna have to lower the window eventually to get the gate open I'd just as soon get another, functional gate and oil spray it. You can't just break the glass because the lock will not release until the regulator is fully down.
I can sympathize with the sticky window situation; mine had the same issue when I bought it. I used prybars to get it to drop initially, then removed the regulator and soaked it for 2 days in oil. Took some time, but it free'd up.
Old Apr 16, 2008 | 04:12 PM
4bytruckin's Avatar
or you can crawl inside and remove the trim panel . remove the for bolts to the motor assembly and drop the entire unit to a manageable height . use some pb blaster on the track or just drill out the runner wheel till it drops. or just break it
Old Apr 16, 2008 | 05:11 PM
BackCountry4Runner's Avatar
Or maybe just use a cargo net? It'd be lighter and waaaayy easy.
Old Apr 16, 2008 | 05:16 PM
bigtrucknwheels's Avatar
I think he wants it like an actual tailgate though, right? Like, sit on it and use it as a cargo extension tailgate? wouldn't be all that much fab work if you know how to weld, I wouldn't think. Plus it'd be cool as hell!
Old Apr 16, 2008 | 05:27 PM
Flash319's Avatar
No he lives in canada like me and you can't get a tail gate that is not rotten through for less then a grand. He wants to get rid of the rusted gate that is unrepairable.
Old Apr 16, 2008 | 05:31 PM
bigt's Avatar
yup.. no need for one when im gonna garage it or cover it when its parked... only get ridin to the trails... i might just fix the rust on my gate and weld a new peice of metal like a tail gate with no window if that makes sense....
im going to take a look at my buddys truck and see how different the mounts are..
by the way all the mods in my sig im going to be taking pictures of.... just scraped off the mud from when i had to get towed 4km out of the bush by a jeep asfter 233km the original clutch went.. and a tree stump took out a brake line..
Old Apr 16, 2008 | 06:26 PM
Flash319's Avatar
oooooooooooo you said the J word and towed in the same sentence. Boo Hiss.
Old Apr 16, 2008 | 06:27 PM
bigt's Avatar
yup twas embarassing... but he has 35k in a jeep so anything can be nice
Old Apr 16, 2008 | 07:14 PM
Noltz's Avatar
I didn't realize you were so close to me. Let me get ahold of a bud at another shop. He bought a tailgate for $250, mint shape, imported from Japan. I think he picked it up in Mississauga.
matrad
Aug 26, 2024 08:21 AM
Weidle
Jan 21, 2019 05:39 AM
voiddweller
19
May 2, 2016 09:10 PM
greenmachine93
Jun 25, 2015 07:50 PM
Bajawfo
Jun 16, 2015 07:31 PM
