transfer case fill plug
Old Dec 3, 2009 | 06:23 PM
Just Learning's Avatar
dumb ? the fill plug to the xfer case is that the one on the top thats looks really hard to get to, ?? i have done tranny and both diff, ( oh ya if you have read my other ? about the read plastic cap in the front diff---- yep it came out in very very little parts - no worry on my part it got shredded) any way how do you get gear oil in there????
Old Dec 3, 2009 | 06:24 PM
waskillywabbit's Avatar
Easiest way to fill IMO is pull the shifter OR COVER PLATE and fill it until it dribbles out the fill plug.
Last edited by waskillywabbit; Dec 4, 2009 at 01:41 PM. Reason: So DC will get his undeez out of his crack
Old Dec 3, 2009 | 06:26 PM
TinMan's Avatar
Look on the back of the case where the drive shaft comes out. at about 3 oclock you see a 24mm bolt head. remove and fill to it either just starts to run out, or you can stick your little finger in and it gets on the end of your finger.
Old Dec 3, 2009 | 06:41 PM
ok thanks ill look at both options, of course you all know - gear oil dont fow to quick-lol god it can take some time to fill
Old Dec 4, 2009 | 01:26 AM
TinMan's Avatar
go to autozone and get a cheap pump for the gallon size jug of oil. puts out about an oz on each pump.
Old Dec 4, 2009 | 11:09 AM
Keith B.'s Avatar
Originally Posted by waskillywabbit
Easiest way to fill IMO is pull the shifter and fill it until it dribbles out the fill plug.
This fills the transmission, but not the transfer, right?
Old Dec 4, 2009 | 11:55 AM
i have thought about the gallon pump but i have quarts, so it don't fit any other way??
Old Dec 4, 2009 | 12:27 PM
DupermanDave's Avatar
What other pumps can you use for filling the transmissiont-case? Can you use a gasoline siphon hand pump?
Old Dec 4, 2009 | 12:34 PM
shaeff's Avatar
I always use a hand pump that screws on the top of the gear oil bottle. You can find them at pretty much any marine store. Mine has been around for several years with no signs of leaking/breaking. Works great every time.
Old Dec 4, 2009 | 12:46 PM
DeathCougar's Avatar
And if he has a forward shifting case?
Best way to be sure is to remove the fill plug (about 1/2 was up the Tcase, should be a 24mm socket) and fill until fluid comes out.
Old Dec 4, 2009 | 01:03 PM
All gear driven tcases have a top cover plate or shifters whether or not the tranny accepts top or forward shift tcases.
Old Dec 4, 2009 | 01:35 PM
So then you should have put "remove the shifter OR the cover plate"
Old Dec 4, 2009 | 02:34 PM
yoterr's Avatar
i filled the tranny through the shifter, with the 1 quart bottles with he nozzle on the end, doesnt take long if you have man muscles and can squeez the bottle same with xfer i just did it through the fill bolt tho....but i also have 7" of lift so i just sat under there and did it..
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
Tykiller1994
Aug 10, 2015 07:49 PM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
crashburnoveride
Jul 10, 2015 06:39 AM
