Tell me if I repaired rust the right way
Old Nov 24, 2009 | 06:40 PM
#1Grunt's Avatar
hey guys I had minor rust on my right quarter panel about a dime size, I ground it out and treated it with rust inhibiter on both sides and then put short strained tiger hair in it,sanded, bondo,sanded,glaze putty, and primer. I also had same problem on right fender but it wasn't through metal just pitted i repeated same steps on it. It looks great but will it last? Any info or ribbing would be greatly appreciated LOL thanks guys
Old Nov 24, 2009 | 06:50 PM
davo247d's Avatar
sounds right to me lol
Old Nov 24, 2009 | 07:02 PM
#1Grunt's Avatar
Sweet thats the 1St time I ever really tried to fix rust the right way(not just feeling full of bondo an saying to hell with)
Old Nov 24, 2009 | 10:28 PM
vwfastg60's Avatar
No, To get rid of the rust youhave to cut and weld. The POR15 and Chassis saver is hype(tried both) Even treating as directed it doesnt do anything. Really you need to cut about an inch on each side of the rust and weld in the patch pannel. Ues Epoxy primer and quality body filler. Seal it and spray it with real paint....Expect to see the rust again....
BTW heres pics from a car i am building for my dad. The same method was used on "surface rust"
this was after cleaning it with a wire wheel
this was pre cleaning for patch pannel.
Rust was in the strut tower but thank god it was in the inner fender and not structural.
The metal stuck to the filler and the fiberglass stuff was in a perfect chunk
Old Nov 25, 2009 | 06:55 PM
#1Grunt's Avatar
thanks buddy for the insight
Old Nov 25, 2009 | 08:21 PM
4runnerx3's Avatar
Sandblasting and metal etching primer.
Old Nov 27, 2009 | 03:18 PM
#1Grunt's Avatar
well guys I am almost done with rust repair, I found quite a bit more than I originally thought. Thank heavens its done. I 'll post final pics
Old Nov 27, 2009 | 03:32 PM
#1Grunt's Avatar
Finished Product here, Tell me what you think.
Old Nov 27, 2009 | 03:35 PM
#1Grunt's Avatar
Not really finished just getting ready for paint.
Old Nov 27, 2009 | 03:43 PM
pwd's Avatar
pwd
Nice, can't even tell you did anything haha. How long did it take you approximately?
Old Nov 27, 2009 | 03:54 PM
#1Grunt's Avatar
I had about three hours in labor involved, The thing that took so long was letting the primer dry, block sanding, re-priming(cause it was so cold)
indawire
Nov 29, 2015 05:05 AM
_Nicco_
Sep 21, 2015 03:06 PM
Pocoyota
Sep 8, 2015 02:41 PM
fabing455
Sep 7, 2015 08:08 AM
Ryall
Sep 2, 2015 06:48 AM
