ignition timing and power
Old Dec 3, 2009 | 09:35 AM
redneckandy's Avatar
my truck seems to be running good. however i know the timing is supposed to be 5 degress btdc and mine is at about 15 btdc. is this going to cause power loss or any other problems for me? i tried gettin the timing right but i have no more room to turn the distributor, its at the end of the slot.
Old Dec 3, 2009 | 09:40 AM
xxxtreme22r's Avatar
how did you check the timing, engine has to be warm and you have to take off the vacuum hose off the distributor and plug the hose. I am assuming this is a 22re.
Old Dec 3, 2009 | 09:51 AM
yea its a 22re, i did it the way the haynes manual said to. i didnt kno u had to disconnect a vacuum hose tho?
Old Dec 3, 2009 | 09:59 AM
yes the vacuum hose gives the distributor additional advance 10-12 degrees i think but don't quote me on that. But it has to be off and plugged when you set that 5 btdc.
Old Dec 3, 2009 | 10:14 AM
ok thanks ill try that
Old Dec 3, 2009 | 05:42 PM
thanks 4runna ill check that out. i appreciate it guys
Old Nov 4, 2011 | 10:25 AM
superme88's Avatar
I seem to have lost my vaccume hose for the distributor during an engine swap. No one can sell me the hose until they know the size. Also I can find a diagram or the place on the engine fir the vacuums hose to run to. I see the port on the distributor but where does the other end go?
Old Nov 4, 2011 | 01:23 PM
84 yota ex-cab's Avatar
You only pull off vacuum if it is a 22r carbed motor. The injected 22re needs a jumper wire installed between ports E1 and TE1 in the diagnostics box. It is on the side of the engine fuse box. Get a FSM, it will have everything you need in there!!
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
